MagnetoSound
Re: Help on Neve HPF
« Reply #20 on: January 12, 2011, 09:21:01 AM »
HPF on Igor's schematic is just to the right of r11/12, no?
Uh, you're right, there it is in black and white. I have seen many similar fixed examples, though I always wonder how predictable it can be in effect given variable source impedance ...
I guess if you assume 200 ohms you can just get on with it and let it do what it does. HPF is usually pretty much try-it-and-see-what-happens in use anyway, no?
Dan
I don't think people realize what an embarrassment of riches this place is   -  Paul Gold
SaMpLeGoD
« Reply #21 on: January 16, 2012, 07:28:33 PM »
Is this correct?? I would like to fit a Switchable HPF on this design! Can anyone help???
I saw on the Neve's 1073 Block design using BA182/C there's a lor of 4M7 resistors between the BA182 legs...
Sorry the newbie question, but I just far away to understand filter's design :S
What B- means here? negative voltage? I have no negative rail on the EZ1290 design :(
Thanks a lot for the help!
Eddie
Keep on Rockin' and DIYing!!!!
MagnetoSound
« Reply #22 on: January 17, 2012, 05:00:45 AM »
No, you need to insert the filter between pad P and the blue wire.
In the case of a single positive supply rail, B- means GROUND. You need to ground this point or the shunt won't shunt.
The resistors help to minimise pops when switching.
Dan
SaMpLeGoD
« Reply #23 on: January 17, 2012, 09:40:25 AM »
Really thanks Magneto!
Cheers!!
pstcho
« Reply #24 on: April 08, 2020, 07:55:26 AM »
good morning guys, exactly the topic i was searching for :)
do you think it could work to incorporate the  Pultec filter board at this exact same spot (  between pad P and the blue wire ) ?
Would it make any impedance issue, we sounding stuff ?? deteriorating the effect of the preamp ?
Sorry for the stupid question, im not very educated in electronics
Last post March 09, 2006, 03:20:50 PM
by matthias
Last post November 29, 2010, 07:05:08 PM
by Phrazemaster
Last post March 30, 2012, 02:03:58 AM
by kilmister
Last post June 03, 2013, 09:51:35 PM
by Grayhill
