JohnRoberts said:I don't have a very clear mental image of your system, but allow me to scatter shoot.
Are power supply + and - rails swinging relative to channel grounds when everything is singing?
If yes, what do you see between channel ground and these PS grounds?
Yes, rails swinging wrt to chan grounds, I can measure entire oscillation. All + an - power rails, on all 8 regulator boards, are swinging relative to channel grounds. All 8 regulator boards have same levels. cca 400mVpp @ 1.8MhZ. This is relative to three grounds. Relative to fourth ground level is 200MHz Vpp.
Actually, even if I measure between channel grounds, and regulators 0V, there is same oscillation. It is 1.8MHz 400mVpp at 3 grounds, and fourth ground is cca 200mVpp.
So entire regulators scheme is swinging relative to channel grounds. And even channel grounds inside mixer are swinging relative to common ground point between smoothing caps in external PS box.
If the PS ground is clean wrt channel ground, while PS + and _ are swinging up and down, the PS needs to get stiffened up wrt to it's own ground.
If the PS ground is swinging wrt the the channel ground then that path needs to get stiffened up. (easier to say than do if it is a length of wire, with inductance, etc is involved).
Both PS ground and rails are swinging wrt to the channel grounds. Or opposite. And even channel grounds inside mixer are swinging wrt to remote channel grounds in external transformer/rectifier/smoothingcap box.
There is a compliance somewhere between the PS ground and channel ground that is allowing the opamps to make the rails swing up and down (same as a common emitter amplifier stage The opamp power pins are like the collectors and the opamp output is like the emitters).
FWIW you should be able to make the who thing work with 10 ohm resistors in series with every PS line and even the grounds, as long as there is adequate local PS decoupling (you need to let the current coming out of the opamp output pins, get back to the PS rails locally).
All channels already have 10ohm resistors in series with PS rails. For test I inserted 10ohm resistor in reference to ground for regulator boards - nothing changed.
Basically I have two power supplies, first one feeding second. First one is in remote box, 3m of cable, and is made of transformer, rectifier diodes, 4x10000uF smoothing caps and 100nF bypas caps. All channel grounds and reference ground for regulators are tied back to a point in between 4x smoothing caps.
Second power supply are 8 regulator boards, which are getting ground reference and +/- voltage from first external supply.
I dont use regulator reference as channel ground. Channel grounds go all the way back to first PS. Thus second PS reference (0V) can swing relative to channel grounds. Second PS (8 regulators) reference for 0V is tied back to first supply, but through 3m cable. I tried to connect second PS's reference directly to channels within mixer, but nothing changed, osc remains.
It is always logical, after you find it... been there, done that... you are not the first or last...
Thnx for encouragement. I'm totally lost.
