mista min
- Joined
- Jan 21, 2011
- Messages
- 113
Hi! New guy here! I have a question. How can I get an 6AC7 tube to work in the G7 circuit.
Ok... so I read lots of the META. I already know which body I wanna use and I even created a thread on Gearslutz asking this question. Even asked a collage of mine to look at the thread and see if he could answer my question.
I've gotta some good tips so far, but I am stuck because I honestly do not know enough about circuits to comprehend what I must do.
Here is all the info I have acquired. That I've also posted at Gearslutz.
Mechanical Data
Bulb .......................................... MT-8
Outline ....................................... 8-1
EIA Base ...................................... 8N
Cathode ....................................... Coated Unipotential
Mounting Position ............................. Any
Electrical Data
Heater Voltage ................................ 6.3 V
Heater Current ................................ 0.45 A
Maximum Heater-Cathode Voltage
Heater Positive with Respect to Cathode
DC Component .............................. 90 V
Heater Negative with Respect to Cathode
Direct Interelectrode Capacitances (approx)
Pentode
Input ......................................... 11 pf
Output ........................................ 5 pf
Grid to Plate ................................. 0.015 pf
Maximum Ratings (Design Center Values)
Pentode
Plate Voltage ................................. 300 V
Grid No. 3 Voltage ............................ 0 V
Grid No. 2 Supply Voltage ..................... 300 V
Grid No. 2 Voltage ............................ 60K V
Plate Input ................................... 160 W
Plate Dissipation ............................. 3.0 W
Grid No. 2 Dissipation ........................ 0.38 W
Grid No. 1 Circuit Resistance
Self Bias ................................... 250K Ω
Characteristics and Typical Operation
Class A Amplifier
Grid No. 2 Voltage ............................ 150 V
Grid No. 1 Voltage Derived from
Cathode Bias Resistor ....................... 160 Ω
Plate Resistance (approx) ..................... 1M Ω
Transconductance .............................. 9000 µ
Plate Current ................................. 10 mA
Grid No. 2 Current ............................ 2.5 mA
Class A Amplifier
Grid No. 2 Voltage ............................ 300 V
Grid No. 2 Dropping Resistor .................. 60K Ω
Also
IO
1 - m
2 - h
3 - g3
4 - g1
5 - k
6 - g2
7 - 7
8 - a
From Jakob E.
"This is probably the main question: How does this tube act with a much-larger grid-bias resistor - in condenser microphones these are from 100M Ohms to several GigaOhms. But tube data alone does not tell the full story - you need to set up the circuit and try the tube in real-life.
A hint could be trying to under-heat the tube (turn down heater voltage) - often this has good influence on the required grid leak resistor.
Jakob E."
So my questions are basicly how do I have to wire the tube as the different pin-configuration confuses me?
And also what values need to change on the capacitors so that I can run a heater voltage of 4.5volts? Also, what value should I insert in the power supply before it hits pin6 to do this? Should it be right after LM317T or after the two joints?
Also, is 4.5 volts too low? Should I send more or less 5 volts? Also, how do I adjust the amperage to go up to .45 A from the original .2 A?
Any help would be greatly appreciated! Also, perhaps somebody could draw out the differences. I know that's a lot to ask for, but I think I would really need this to understand it properly.
min
Mechanical Data
Electrical Data
Pentode
Pentode
Class A Amplifier
Class A Amplifier
Also
IO
1 - m
2 - h
3 - g3
4 - g1
5 - k
6 - g2
7 - 7
8 - a
From Jakob E.
Jakob E."
min
