EAR 825 EQ-Dont quite understand......?
valvusmusicus
Active member
Hi all
I understand the EQ part of the circuit-but not sure how it is implemented into the circuit-this is basically a pultec network is it not? Why are the transformers neccessary? are the middle 3 triodes and associated components a discrete op-amp? Ive been trying to work out how it works (with my limited knowledgfe) but....alas!!
anyone help-I would love to build this-as from reading posts, it seems to be very different to other topolies about ???
Without a schematic no one will likely have a clue as to how to answer your questions . . .
here ya go
Not at all pultec-like or passive - it's a simple boost/cut L/C gyrator circuit halfway inside the feedback loop of an amplifier.
More or less like a standard 1980's car-radio graphic eq, but with a tube amplifier.
http://4.bp.blogspot.com/_FdGFE8NBDgc/TCb9RaaqLRI/AAAAAAAADm8/Z8fWHTxw6gA/s1600/Ten-Band_Equalizer_Circuit_Diagram.GIF
http://farm6.static.flickr.com/5206/5278034584_9a51733691_b.jpg
Jakob E.
Aaaah!!.the mists are clearing!! I see now what you mean-just confused by the complexity of the EAR schematic.
hanks to all who replied :)
Thansk Lassohar et al-sorted now-will go ahead and build my own version, and hopwfully post pics when done-
Any ideas on suitable iron for this?
I'm guessing step down on the input and a similar step up on the output.
Looks like there's feedback taps on the interstage and output transformers.
Mark
