andia
Filtek MK3 -6db drop when engaged
« on: April 08, 2011, 06:45:24 AM »
Hello!
I have a filtek mk3 eq here that i'm racking up. the eq seems to work fine, the problem is that the volume drops -6db when I engage it. Does anybody have an idea what could cause that drop in volume?
thank you very much,
andi
hobiesound
Re: Filtek MK3 -6db drop when engaged
« Reply #1 on: April 08, 2011, 07:20:44 AM »
are you running it balanced or unbalanced ?
greetings,
Thomas
andia
« Reply #2 on: April 08, 2011, 07:30:37 AM »
hey thomas, all lines are balanced. the eq has a "bypass-switch" and as soon as I flip this switch to "eq on" the volume drops...
thank you
Junction
« Reply #3 on: April 08, 2011, 08:42:43 AM »
sounds like you are losing one leg of the balanced input or balanced output when you engage it
kante1603
« Reply #4 on: April 08, 2011, 08:46:06 AM »
Exactly what I was thinking of-a 6dB drop nearly always implies a switch from balanced to unbalanced.
Good luck, ;)
Udo.
Ptownkid
« Reply #5 on: April 08, 2011, 09:05:18 AM »
OT; Kante, great profile pic!
Last post April 05, 2020, 04:23:14 PM
by synthiaks
Last post May 31, 2008, 12:51:33 PM
by maxime
Last post January 24, 2018, 10:32:46 AM
by flextone
Last post October 21, 2011, 01:06:45 PM
by bootyfox
