keeeth
Please help with wiring my Neve rack
« on: February 21, 2011, 06:19:07 PM »
Hi guys
I need some help if possible.
I have a Neve 1084 module and I had it racked by a local tech into a dan alexander rack [which was originally for an Audix module].
The thing looked a mess but as the tech was good it worked well and sounded great.
Recently I had a face plate made and drilled a case for the module and began working on racking it up. I've pretty much done it but I've hit a roadblock.
When I snipped some of the cables for the switches I wrote down where they were wired to but I've now lost the bit of paper it was written on and now I can't get it back together.
I can't afford to get my tech to do it at the moment and I need to have the unit functional and I also feel I could learn a bit from doing it. I was hoping if I give a quick run down on what is included, someone could give me a few pointers as to where everything needs to be wired.
 I have an elementary knowledge of  electronics, but I think it will be enough to get it done as all the parts are there and for he most part already wired.
Here is what's there.
Neve module with pcb connector fully wired to all relevant pins
all xlr and trs sockets wired into pcb connector
Full 24v and 48v Dan Alexander power supply
2x switch and 2x LEDs for power and 48v
So basically everything is connected except the switches and LEDs.  Could someone tell me where these should be wired to?
Many thanks
« Last Edit: February 21, 2011, 06:22:22 PM by keeeth »
signalflow
Re: Please help with wiring my Neve rack
« Reply #1 on: February 21, 2011, 10:44:33 PM »
Some pics would help.
-Casey
The shortest distance between two places is a nap.
keeeth
« Reply #2 on: February 22, 2011, 06:26:22 PM »
Ill take some pics and post tomorrow but I honestly don't think they will help, all the cables are tied up and most of the wires are hidden so you can't tell where they go, just what components are there.
Is this really so project specific? Is there not a generic schematic to show how to wire up 2 switches and corresponding LEDs for power and 48v?
Everything else is wired up.
r2d2
« Reply #3 on: April 08, 2011, 02:45:20 AM »
any update ?
(checked around and at "Meta" but nothing about racking vintage neve modules ,
like:
psu power required ,
main transformer inside or outside the modules box
"better" ground-gnd wires scheme / setup
also metal works tips as well )
peace
..... Cracking D.Vader Firewall ...  II-)
pucho812
« Reply #4 on: April 08, 2011, 03:14:39 AM »
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
r2d2
Re: Please help with wiring my Neve rack New
« Reply #5 on: April 08, 2011, 07:00:18 AM »
Thanks for post "Pucho"
more about racking n-e-v-e
is so "wellcome"
because module connetcor it's not ever the same also 29 pin was used
about main power transformer ,
it's possible place it inside the rack box
without "humm" issues?
there some scheme about a "star" ground setup include xlr pin 1 ?
peace
« Last Edit: April 08, 2011, 11:18:29 AM by r2d2 »
Last post October 17, 2007, 10:03:39 PM
by Emperor Tomato Ketchup
Last post November 17, 2006, 05:25:08 PM
by carloff
Last post March 13, 2009, 02:44:11 PM
by maxime
Last post July 22, 2009, 05:57:54 PM
by charlie2012
