MagnetoSound
Re: PYE Compressor/Limiter Thread *boards shipping* BOM up!
« Reply #1000 on: March 10, 2018, 02:48:01 AM »
The shunt goes across the meter (between + and - ). The series resistor (maybe there is one already if you have a trimmer) goes ahead of it. Or between - and ground if you prefer.
By adjusting the two values you should be able to set a zero point and a sensible deflection range.
I cannot offer values, sorry. They will depend on your meter more than anything, but the shunt will probably need to be close to the resistance of the meter coil.
Dan
I don't think people realize what an embarrassment of riches this place is   -  Paul Gold
Spencerleehorton
« Reply #1001 on: March 10, 2018, 04:20:10 AM »
Ok so we are probably talking about putting in 100R trimmers then and having a twiddle right?
website: www.mohawkstudios.co.uk
email: [email protected]
If it hisses its probably the wrong impedance!!!
Or a snake!!!
« Reply #1002 on: March 10, 2018, 05:49:46 AM »
That's how I got my meters to zero, by turning r52...as it didn't seem to affect the sound of the unit. I tried dialing it down and up and listening while compressing heavy/soft, etc. Nada...didn't do anything that I could hear at all....but of course, that's subjective.
That's why I mentioned earlier in this thread that I wish he had labeled the trimmers on the board(obviously, there's other logical ways to deduce what does what, I just don't know how to do it).
All of my other trimmers were pre-trimmed to the suggested values and left, and it's been good ever since. I'd still like to know what's what tho...
Spencerleehorton
« Reply #1003 on: March 10, 2018, 06:10:25 AM »
Yes that’s what I have found, R52 doesn’t effect sound but seem to have the most influence on the meter position, but with mine I can’t adjust it anymore as it’s fully one way, so I need to change something to allow a bit more range to be adjusted?
Or a snake!!!
MagnetoSound
« Reply #1004 on: March 10, 2018, 06:41:47 AM »
That sounds like a fair starting point.
Dan
Spencerleehorton
« Reply #1005 on: March 10, 2018, 07:22:55 AM »
I wondering whether TR13 has effect on the meter position, as I have same values in both channels but one meter very nearly lines up and the other doesn’t?
I might test both and see if they are different?
Or a snake!!!
MagnetoSound
« Reply #1006 on: March 10, 2018, 10:29:20 AM »
Looking at the schemo I have on file, I think TR12 is the one you're concerned with.
I've just spotted that there is a 1k5 resistor (R65) which is connected across the meter lines.
I would try reducing the value of this resistor, in order to bypass more of the drive current away from the meter. This might bring R42 into range. 😉
Transistor matching between channels is never a bad thing, though.
Dan
MagnetoSound
« Reply #1007 on: March 10, 2018, 10:49:30 AM »
Or increase R67.
Dan
Spencerleehorton
« Reply #1008 on: March 10, 2018, 01:49:01 PM »
top darts dan, hopefully i'll get a minute and try this! will report back.
Or a snake!!!
Spencerleehorton
« Reply #1009 on: March 13, 2018, 09:58:35 AM »
HI All,
I have just changed R65 to 1k trim pot and this works well to dial down the meter to zero, so if you need to this works great!!
Or a snake!!!
MagnetoSound
« Reply #1010 on: March 13, 2018, 01:36:33 PM »
Glad that fixed it for you.
Dan
Spencerleehorton
« Reply #1011 on: March 13, 2018, 02:46:10 PM »
Yes thank you very much Dan.
Or a snake!!!
« Reply #1012 on: March 16, 2018, 02:57:30 PM »
We still don't know what all the trimmers do, or at least I don't. Namely R52.
Ilya
« Reply #1013 on: March 16, 2018, 03:03:47 PM »
R52 is decay time as marked on the schematic. It works on my unit just fine. Although it may not work correctly with 555 oscillator.
PCBs, enclosures and build guides at www.rackneve.com
Rlucas41
« Reply #1014 on: March 16, 2018, 08:11:46 PM »
I have calibrated the oscillators and and balanced the channels in/out... I was able to use R52 to zero my meters but do feel indeed it adjusts decay as well...  but it works for me. This thing sounds smooth and tight, it can really squish but is also smooth on the vocal tracks I have tried it on and it does indeed sound great on acoustic guitar... but it is especially groovy on the drum buss! I don't know that it will see my 2buss very often but it will get used in every mix from here on. it is very quiet too! Now on to the next build :o
MagnetoSound
« Reply #1015 on: March 17, 2018, 02:04:42 AM »
R52 is definitely for calibrating DECAY time, but does have a slight effect on the idle position of the meter.
On the original Pyes, the meter always tends to sit about half a dB or so above zero when DECAY is properly adjusted. Just perceptible on an original unit, but possible to ignore once you know about it.
I strongly suggest calibrating the meter to zero first using R42 (and R65), with R52 (DECAY) all the way down. Then, to calibrate R52 go to the longest setting and calibrate recovery time if you can arrange a suitable test signal (drum samples with reverb tails of known duration are good for this). Alternatively, you can calibrate at the 100mS setting for the shortest undistorted recovery time (pick a signal with good LF content) if you feel the shortest setting is the most crucial.
Dan
« Reply #1016 on: March 18, 2018, 09:22:47 AM »
Hey, thanks for pointing that stuff out guys. Actually, I think I remember seeing the notes for the trimmers at some point on the schematic, now that someone mentioned it. I'll dial those decay trimmers up a few turns next time I have it open Magneto..thanks for that advice.
vitopower
« Reply #1017 on: July 20, 2018, 02:40:59 AM »
Is there anyone who is willing to describe the process and parts required for building the oscillator transformer?
« Last Edit: July 20, 2018, 10:03:49 AM by vitopower »
Ilya
« Reply #1018 on: July 21, 2018, 09:04:27 AM »
The transformer is basically several turns of wire around a ferrite ring. You need to find the ring with the correct permeability to get the osc frequency you want. This can be done with some experimenting.
vitopower
« Reply #1019 on: July 22, 2018, 11:26:06 AM »
Thanks, Ilya!
Last post April 20, 2006, 01:13:04 PM
by cannikin
Last post August 15, 2006, 05:45:57 PM
by API
Last post May 29, 2014, 11:43:50 AM
by EvLoutonian
Last post June 01, 2020, 06:08:31 AM
by dunk91
