vitopower
Re: PYE Compressor/Limiter Thread *boards shipping* BOM up!
« Reply #1020 on: July 22, 2018, 11:26:06 AM »
Thanks, Ilya!
kml23956
« Reply #1021 on: December 09, 2018, 07:04:49 PM »
Does anyone have the documentation for this project that they would be willing to share?
« Reply #1022 on: December 24, 2018, 07:18:21 PM »
I think the information is posted in the thread somewhere.
Rlucas41
« Reply #1024 on: February 04, 2019, 06:49:16 PM »
Has anyone else got a working unit? If so, what do you like it on?
I love mine on acoustic guitars, drums and drum buss, vocals too.
Spencerleehorton
« Reply #1025 on: February 06, 2019, 06:14:03 AM »
I like mine on overheads and acoustic guitar, haven’t tried it on anything else yet
website: www.mohawkstudios.co.uk
email: [email protected]
If it hisses its probably the wrong impedance!!!
Or a snake!!!
« Reply #1026 on: February 09, 2019, 10:11:40 AM »
Like any good, usable piece of equipment, Pye is a compressor known to pretty much work on anything.
Rlucas41
« Reply #1027 on: February 09, 2019, 01:11:09 PM »
I second that desol! ;D
Mmt50816
« Reply #1028 on: March 12, 2019, 05:39:44 PM »
Im gettin set to start wiring this puppy up and had a few questions. I attached a pic of how i think the pots should be oriented and the way i intend to wire the stereo link. Anyone want to check my work and give me the A-Ok?
Spencerleehorton
« Reply #1029 on: March 19, 2019, 09:07:38 AM »
Have we got a working setup procedure yet?
Or a snake!!!
Spencerleehorton
« Reply #1030 on: March 19, 2019, 04:10:28 PM »
I got a problem with channel 2 now!!
Channel 1 passing audio and can twiddle in some approx settings
Channel 2 not passing audio?
Would be really helpful to have a proper setup procedure
Or a snake!!!
Rob Flinn
« Reply #1031 on: March 19, 2019, 04:13:24 PM »
Dis you see the attached doc
regards Rob
Spencerleehorton
« Reply #1032 on: March 20, 2019, 03:12:15 PM »
Thats great stuff Rob, i thought i'd revisit this unit and see if I could get it working a little better and understand the setup a bit more.
Channel 1 sounds pretty good, I have no idea what everything is set too!!! I just twiddled and looked at the waveform and tried to get the meter working to a decent level.
Channel 2 sounds good now but i get these big spikes!! so I need to revisit the setup and approach it as per your last post calibration.
I also have a trim pot for R65 which helps zero the meter.
Or a snake!!!
Mmt50816
« Reply #1033 on: March 20, 2019, 03:59:36 PM »
I dont know if my pic posted with my last question, but I was wondering if someone could give me a little more clarity on the orientation of the pot pins to the board and the wiring of the stereo switch. The verbal instructions are not making much sense to me about marrying the pins
Rob Flinn
« Reply #1034 on: March 20, 2019, 05:03:23 PM »
1=anticlockwise
2=wiper
3=clockwise
regards Rob
Spencerleehorton
« Reply #1035 on: March 21, 2019, 06:49:55 AM »
Am I right in thinking that these peaks I see happening on Channel 2 are when the compressor is pumping?
Or is it that the threshold is t setup properly?
Or a snake!!!
Rob Flinn
« Reply #1036 on: March 21, 2019, 07:45:46 AM »
Have you tried to set up both channels as per the doc I posted ?
If you haven't then I would do this first & then start making comparisons.   If you have then I would say that if both channels are doing something radically different with the same settings then you have a fault on one channel.
regards Rob
Mmt50816
« Reply #1037 on: March 21, 2019, 03:01:54 PM »
1=anticlockwise
2=wiper
3=clockwise
I understand that is how the pins on the potentiometer are oriented. I am asking which pin goes to which spot on the pcb.  As in does pin 1 go to ground in both the input and output pot with wiper being the middle spot on the pcb?
Which spot on the output xlr is the + and which is - ?
And on the input xlr is pin 3 of the xlr go to the middle spot on the pcb?
Mmt50816
« Reply #1038 on: March 21, 2019, 03:04:06 PM »
Ill post my wiring pic again. Let me know if all thse connections look correct, especially the stereo switch business
Rob Flinn
« Reply #1039 on: March 21, 2019, 05:58:57 PM »
Since they are both level controls it is highly likely that pin 1 goes to ground.
Since both in & out are transformer balanced it will not make a great deal of difference which way you wire them so long as the output is in phase with the input.
Check with your meter which of the input connections goes to ground & you will have found which connection is pin 3 on the xlr.
regards Rob
Last post April 20, 2006, 01:13:04 PM
by cannikin
Last post August 15, 2006, 05:45:57 PM
by API
Last post May 29, 2014, 11:43:50 AM
by EvLoutonian
Last post July 09, 2019, 04:21:55 AM
by fripholm
