MS, Pultec, 1/2-BA283 boards support thread!
Israel
Hi guys, here is the support thread for these boards...
Why I didn't called it MS/Neve Pultec support thread: because many people will find a use
for MS boards and out half of BA283 make-up stage without the EQ boards, others will use
Pultec boards with another make-up stage, etc etc.
I got the Neve+Pultec combo idea from Purusha about a year ago, btw, he offering the cases at his forum,
he told me Pultec EQ sound great...
First, I was doubt. Second, thought a bit....and tried.
Yes, the sound is f@@@ng unbelievable good. What this EQ can do....
On a drum group, I did next thing:
-Cut the lows at S
-Boost a bit lows at M
-Add some hi-mid at M
-Add some highs at S
-Open the S at 2 db more than M with makeup gain
-Compress 3 db at peaks, not more, with MixBuzz1, sc at 80 Hz, ratio 4, attack/release up to yr taste;
Equalize the levels and compare with source.
My impressions from this sound are, of course, subjective, but guys, it is worthy to hear THIS sound once at life at least))
Here are the pictures of a beast done with these boards:
More:
http://s251.photobucket.com/albums/gg291/diy33609/PULTEC_MS/
So, here we go.
I reserving 3 next posts for FAQ, etc. to concentrate all the useful info at the start of the thread.
Reserved#1:
Schematics for MS board and Pultec boards:
http://s251.photobucket.com/albums/gg291/diy33609/PULTEC_MS/EQ_MS_Schems/
DOCUMENTATION:
NeveTec detailed wiring:
http://ij-audio.com/downloads/pult2010_MS_wiring.pdf
Pultec front panel PCB:
http://ij-audio.com/downloads/PULTEC.rar
MS/Bypass board:
http://ij-audio.com/downloads/MS_BYPASS.rar
Make-up stage:
(please check as well ba283_op_stage_info.pdf, it has detailed info on gain switch resistors)
http://ij-audio.com/downloads/BA283_MKUP.zip
Front panel (Corel Draw file):
http://ij-audio.com/downloads/Nevtec_CTL_Q.cdr
Hell mate! Looks insanely good!
How much for full stereo kit? And does the kit include components?
Im in the middle if a build at the moment but this looks like it could be next on the cards.
Updated, added to WM thread:
http://www.groupdiy.com/index.php?topic=29771
I will finalize BOM's etc within few days and post here, tough on time)))
Hi Igor !
looks really great, did you ever try a pultec with a very clean makup stage ?
nicholas
Hi
Is it easily possible (if so can you please explain) to use exclusively decode or encode - i.e. input in MS process with EQ then output LR or vice versa?
This is when applied to stereo Igor stereo pultec where one might input to the eq a Mid side signal, process in mid side then before output decode back to stereo effectively using the unit only as a decoder...
Also will it be documented the resisitors to use for 0.5 db steps?
thanks
Hello there,
is there a B.O.M some where? how do you connect the filters to the make up pcb? ( with wire I know but.....)
and what transformers do the make up pcbs take. They are both Carnhills but is it the line input trannie i need as well as the output trannie?
Kindly
Michael de A
Is there an easy way to implement a gain range switch? To select between 15dB of boost/cut and 5dB for example for more precise action.
Kind regards,
Maarten
received my PCB. Awesome lets go!!!!!!
Question
It says on the control panel 10k log 100k log etc. Can I indeed place pots here? If so, how? I don't want to or need to add switches here as I won't need the gain to be completely accurate or repeatable. Is this possible???????
Kindly
michael de A
OK,
and how do I hook up a make up gain knob to the make up PCB? Totally lost here!!!!!!!! There is a supplied PCB but with no resistor values on them and no way of connecting it to the make up PCB.
Help please. This project is needs a little more info please.....
regards
michael
mylesgm said:
Is anybody offering a case or at least front panel for this?  Not sure I can be as accurate as needed for PCB mount switches.
M
Check out Tat's site.
http://www.diy-racked.com/diy-talk/viewtopic.php?f=7&t=109
Sylvain
Igor,
I have received my PCbs. Please please, if you have any time, talk us through how to put this together, in my case without the ms PCB but with the BA283 make up PCB. I am totally stuck here. I have figured out a BOM by guessing what kinda caps we need but I have no idea how to hook the control PCB up to the BA283 and add a makeup knob, what values to use here etc etc etc ??? ???
Regards
Michael :(
Hi Igor,
Question about MS boards,    I saw you are using zobel/load over each secondaries.
For input trasformer, in my case VTB9046,  what zobel values and Rload for each winding is ok? (to use with this passive EQ circuit Zin)
The same question for output transformer VTB9049
Hello Igor
BA283  Stage (M / S Board Added) which components
I omit?
Choke +   Pot Make Up?
the list is written to omit too - 1k5 R3 R-EU_0309/10 " NOT USED WITH BOARD MS" but there is in your photos.
help please
