Spencerleehorton
Re: CLX-VU Build Thread (DBX 160VU ) UPDATE: REV 3
« Reply #700 on: February 18, 2020, 11:07:30 AM »
Ah ok, my version doesn’t work but it’s all round the wrong way as per the other pic. Will try reversing and hopefully will sort!!
website: www.mohawkstudios.co.uk
email: [email protected]
If it hisses its probably the wrong impedance!!!
Or a snake!!!
Spencerleehorton
« Reply #701 on: February 19, 2020, 01:28:04 AM »
Is there a way of using a 0.5ma Vu meter for this?
What would the resistor config be?
Or a snake!!!
Spencerleehorton
« Reply #702 on: February 19, 2020, 01:35:47 AM »
Looking at R107 it says 3.3k for 1ma meter and 10k for 0.1ma so if I replaced R107 for 10k trimmer I should be able to set about 5-6k and that should be 0.5ma?
Or a snake!!!
Spencerleehorton
« Reply #703 on: February 21, 2020, 11:18:17 AM »
Well I’m not sure the other wiring image works or not!! As I didn’t have the plug in the correct way and then changed it!!
Getting compression but having difficulty setting up correctly.
Or a snake!!!
« Reply #704 on: March 24, 2020, 01:09:51 PM »
Hy
If i check g and led for vu meter with led i meet 28v in place for 5 or 6 volt
I have R125 4,7k solder
Is anybody with same issue?
I dont wont blow led in vu meter (hairball meter 1ma)
Thanks in advance
Last post November 24, 2004, 11:41:13 AM
by
Last post June 28, 2005, 07:11:20 PM
by OddHarmonic
Last post March 19, 2011, 06:21:59 PM
by abechap024
Last post October 15, 2019, 07:19:02 PM
by Zebra_PD
