olafmatt
I'm currently struggeling (again) to make good PCBs. My method is to print the layout onto transparent plastic foil (that does not block UV) and then use a halogen lamp to get it onto the photo-board.
However, I constantly get results that look like 'solarised' photographies: where there was black on the foil the developer removes the photo layer!!!
I tried several different exposure times and today, it seems, I found something strange. One PCB came out perfectly all right, the other one was 'solarised' again. The only difference was that I printed the foils for the bad one today and the good one several days ago.
Is it possible that the ink somehow reacts with the PCB's photo layer? Did anybody of you experience something similar? (for clarification: I print the foils mirrowed so that the ink side is in contact with the photo layer)
thanks for any hints,
Olaf
Olaf
