MrZpliff
Re: Poor Man's Pultec EQP1-A
« Reply #380 on: November 10, 2011, 02:31:35 PM »
If I'd go for a cheap option, leaving the transformers and tube, would it be easy to later upgrade the unit with those parts?
Yes, go for it  :)
Peace
Magnus
www.bitterend.se
« Reply #381 on: November 10, 2011, 06:27:22 PM »
I deliberately made the EQ and tube gain make up PCBs slim enough to fit in a 1U case. I believe several people are building stereo EQs in 1U rack mounting cases.
Mmm.. Excellent :)
Note, however, that the PSU PCB was designed for a different project and will not fit into a 1U case.
« Reply #382 on: November 10, 2011, 06:29:47 PM »
It would be easy to upgrade to input and output transformers. However, the mains transformer would have to be changed if you went from semiconductor gain make up to tube gain make up.
G-Sun
« Reply #383 on: November 11, 2011, 02:49:24 AM »
Thanks Ian!
Think I'll wait a little and see how it goes with that mid-eq. Would be ideal to have it in.
HJFP2, ssl9k, Harrison Ford Filters
My music
erikb1971
« Reply #384 on: November 17, 2011, 09:04:36 AM »
For those interested: I started a feeler for the mid boards that Ian has designed to ad to the pm eqp1: http://www.groupdiy.com/index.php?topic=46575.msg584436#msg584436
When enough people register, Ian will be making dedicated boards!
We are getting way past relatively easy
G-Sun
« Reply #385 on: February 08, 2014, 05:42:42 AM »
Has anyone compared the sound of the Poor Mans Pultec with the original/Rich Mans Pultec ?
My music
« Reply #386 on: February 08, 2014, 06:00:05 AM »
Good question but I don't know the answer. It is not a completely fair test because the poor man's does not have the inductive hi boost - it uses a simpler RC network to save money. The 3 band Pultec board I designed would be closer as this does have an inductor based hi boost. I know Pierre likes the 3 band Pultec but I don't know if has been able to compare it with the original.
anjing
« Reply #387 on: February 12, 2014, 06:43:17 AM »
I never had the chance to touch an original pultec so i can't compare.
The eztubemixer card i used for the amplifiers is solid by itself...
so i don't know if it sounds the same, but it's certainly a high end eq!
Pierre
« Reply #388 on: August 04, 2016, 11:33:06 AM »
Hello!
Anyone know a frontpanel for this project?
Thank you!
Last post July 07, 2008, 11:56:08 AM
by bodega
Last post April 29, 2020, 05:19:48 AM
by ruffrecords
Last post August 09, 2013, 09:29:39 PM
by mikeyB
Last post May 27, 2018, 06:48:06 PM
by mylesgm
