mav_kbd
Member
- Joined
- Apr 26, 2010
- Messages
- 16
Hello, I have some doubts about cables capacity related to impedance-balanced circuits.
Normally I select the cables that I use to be sure that have low-capacity. In a real balanced circuit, I measure only the capacity between conductors and screen, but what happens using impedance-balanced circuit where, in the output stage, the "cold" pin is connected to ground with a resistor? I have to consider also capacity between "hot" and "cold"?
