µA7812 latch-up
Steffen
Germany
some of us had problems with 7812 latchup in the ssl clone (7812 output hangs @ -0.6V). are LM317 regs known to be safe?
steff
Hi Steff,
It was me who had the problem. It is mainly when double-single-rectifying a single AC voltage to acheive symmetric supplies that the problem occurs. It happens when the negative half-wave is coming first, charging the negative side first, dragging down the positive side to less than -0.6V before this gets started.
http://wwwd.national.com/national/PowerMB.nsf/88bc465ea04c97a58525620b0040cc4a/FB19F9D1B2E1D9B888256DE2003DB534?OpenDocument
For some unknown reason, this only happens with certain brands of 78xx's - and not with 79xx's.
I don't know if the 317 acts the same..
Jakob E.
yepp....I made a new ssl pcb and used double-single-rectifying wich is definately the reason for this bahavior. the funny thing is this only seem to happen with 12V regs since I use this PSU scheme a lot and never had that kind of trouble.....
so I´ll check out if lm317 will work...otherwise I´ll do some sort of neg rail soft start circuit....
steff
have to check this out: I´ll let ya know how it turned out....
steff
No, those protection diodes won't do the trick, as their forward voltage is high enough that latch-up still occurs. I've been there.
You would need germaniums for this - power types. National recommends a 2N3612, 10A germanium power transistor (!) in their application note:
http://wwwd.national.com/national/PowerMB.nsf/(approved-attachments)/E335D52E00D4244D88256DFD00627DE5/$File/AN-103.pdf
..page 10..
Jakob E.
Would a schottky diode work instead of the germanium transistor?
Best regards,
Mikkel C. Simonsen
A 78XX is not just a 78XX, there can be quite a variation between different manufactures and batches! :evil:
LM3X7 seem to be much more constant quality, so do the LTs.
Just working on my SSL and the same problem occured.
On my 7815 is written:
TS7815
S
3A1 CZ
Maybe we can collect some informations about affected brands.
Monday I will get a different brand and test again.
hi,
last week I built the power supply for my calcrec eqs
everything was fine but I had only 10,6 V at the uotput...
I changed the 7815 from another brand and everything was working fine...
the bad 7815 is labled:
TS7815
S
3A1 CZ
no wondering anymore.... seems that "reichelt" has a bad series of 78xx
what about the 79xx are they ok ??
matthias
I´m using this little softstart circuit to get rid of that latchup thing....no problems since then...
steff
The simple - but not as power efficient - way would be to charge the first reservoir electrolytic slower - through a resistor - ensuring that V- won't be charged much faster than V+.
When we had this discussion on the old forum, someone pointed to a commercial circuit (I think it was a Rane) that did this.
Jakob E.
It seems like we could conclude that the TS78xx series of regulators are marginally designed. Yes, they work fine under conservative voltages/load, but they are very easy to latch up.
Stay away from those.
Jakob E.
No, never.
I haven't got a clue why.
Maybe it's because the 79xx types are not so well protected as the 78xx's. You often see burnt-out 79xx's, rarely 78xx's
Jakob E.
