pucho812 said:
does anyone have any info on this op amp? how close is it to a 2520?
late to this (shows how often I visit)
The story I was told long ago by Mr. Wolff was that the 2510 was derived from another opamp api made for a time called a 2525.
The api 2525 had the same form factor and pinout as the api 2520. API produced a number of consoles full of 2525's... I rebuilt one of these - a 1604 and it sounded pretty sweet - much faster with less midband clutter. 2525's came along at the time api introduced the "Gold Seal" consoles, the last hurrah for API until Paul took it over and made the big Discrete Series desks. Most of the Gold Seals sold into Japan it seems. Some or all went out with 2525's in them.
But 2525's had a problem. The output stage was not always fast enough to keep up with the input and second stage. This was device dependent so entire batches would have very high failure rates while others are still ticking along to this day. The 2525 was abandoned... it could have been fixed but API was fading and why bother at that point.
When Paul was looking for a smaller faster amplifier to use in the 550-S module (the ones that fit into Sony MXP3000 consoles) he stripped the large output stage off the 2525 and the 2510 was born.
The 2510 can't drive much of a load... 5K is about as low as you should go and the higher the better. The 2510 conceptually was a good thing. They sound pretty good and can be used, with some care, in many places in a console or other product where you don't have to drive anything serious like a transformer. They run on higher voltage rails and draw less current. They are compact.
and here are a couple really early ones that were never potted, just found them in one of my parts drawers (trying to weed things out) and that is how I stumbled into this thread
