chefducuisine
U47 inspired clone (Based on a Flea DIY Kit)
« on: April 27, 2011, 03:32:19 PM »
here is my version of an U47 inspired clone attempt:
The whole thingy is based on a Flea DIY Kit with the following options:
- K47 capsule, skinned by Thiersch
- BV12 Trafo
- Chrome Grille
- Binder connector
- EF86 Socket
- U47 Type schockmount
The schematic is roughly based on Max's (ioaudio) MK7 because of the tube (EF86). Many thanks for the inspiration, Max!!! ;)
I have changed the polarization scheme to incorporate 9 steps on the power supply. :D
Please see my galery for more detailed pictures without the cover.
http://twin-x.com/groupdiy/thumbnails.php?album=454
The result is awsome. ...Sounds great! ...having a lot of fun currently. :P
Regards,
Chris
« Last Edit: April 28, 2011, 02:55:15 AM by chefducuisine »
strangeandbouncy
Re: U47 inspired clone (Based on a Flea DIY Kit)
« Reply #1 on: April 27, 2011, 04:09:57 PM »
 . . . very nice Chris . . .
      AndyP
. . . . RUH ROH . . . . .
« Reply #2 on: April 28, 2011, 06:58:24 AM »
Love it Chris!
Have you put it through the ropes?  How's the sound? Let us know! :)
Marcos
tommypiper
« Reply #3 on: April 28, 2011, 11:51:57 AM »
Looks schliiick.   :)
WHeere did you get the PS enclosure?  (Looks like the face plate comes off so you were able to silk screen the graphics, where did you have that done?)
Imagine a wet, slightly chilled from its gas release and decompression, with water droplets condensing, sucking surface tension, slowly sliding down the side, capped by a healthy virgin froth on top..
mata_haze
« Reply #4 on: April 28, 2011, 06:53:45 PM »
BEAUTIFUL!!!
how does it sound?
Mattia.
mik
« Reply #5 on: April 28, 2011, 06:59:39 PM »
Looks schliiick.   :)
same Q. here
M.
chefducuisine
« Reply #6 on: April 29, 2011, 04:08:12 AM »
The Power Supply case is from Conrad:
http://www.conrad.de/ce/de/product/522970/KUEHLRIPPENGEHAEUSE/?ref=reco
It consists of two halves. The Frontplates are screwed on. See here
http://twin-x.com/groupdiy/displayimage.php?pid=4376&fullsize=1
Frontpanels have been engraved by Frank (nrgrecording).
Chris
e.oelberg
« Reply #7 on: April 29, 2011, 04:45:18 AM »
where did you get the mains transformer and the PSU PCB ?
nicholas
chefducuisine
« Reply #8 on: April 29, 2011, 06:07:13 AM »
The mains transformer is custom made.
The PS PCB is based on Max's MK7 PS design with a regulated heater section based around an LM-317.
I did the layout myself. Because it is based on Max' design, I did not publish it.
As described above, the polarization scheme has been changed to incorporate a 9-pos pattern selector.
Chris
e.oelberg
« Reply #9 on: April 29, 2011, 05:12:05 PM »
pardon me, but where did you get that nice small trafo made, I'm always looking for small tx for this specs
nicholas
e.oelberg
« Reply #10 on: April 29, 2011, 05:14:47 PM »
you could consider repacing the lm317 with a lt1085 they are more quiet
nicholas
SKJGProject
« Reply #11 on: May 02, 2011, 08:47:13 AM »
looks great & expensive....how much have you paidfor all parts?
I used to date a blind girl. Her name was ::… ..:.: .:::. .::.. ….: .:.::
chefducuisine
« Reply #12 on: May 02, 2011, 03:33:12 PM »
Total Price for material, power supply, shockmount & Capsule skinning: ca. 1200.- EUR
Nicholas:
The Trafo was made by a friend's fathers company - they normally do high power trafos.
It has been wound sundays as the owed me a favour...
It is not available commercialy.
I'll try the LT1085 - Many Thanks.
Did you check Tube-Town.net for trafos? They are similar to mine, but a little bit bigger.
A lot of people asked how it sounds:
Well, sound talk is difficult. I have compared and used this mic for a while and I can say: This thingy has B A L L S !!! Hard to discribe but there is an authority in the sound this mic produces - even tested blindly against commercially sold Mics of the top class - the only thing I couldn't compare it to was an original U47.
No Sibilance, but more shine, more meat, more detail, more air, the bass simply blows you away - even my own (crappy) voice  sounds terrific.
I know this sounds enthusiastic - but please built one for yourself and do a blind test! I promise, this is money well spent.
At first I was a bit uncertain because I did not use a VF14 (Those prices are ridicoulus). Probably it would sound even better.
Other than that the critical components of this built are as close as possible... it wasn't my intention to do an historically correct clone - this one is made for useage!
For now I think the decision was right to go for an EF86 / transformer combination.
Mr. Thiersch did an excellent job on the skinning of the capsule (as always).
Many thanks to Max' for his MK7 circuit - this mic would probably not have been made without its inspiration!
Unfortunately the Flea kit is sold out now - I would love to built a second one...
Regards,
Chris
« Last Edit: May 02, 2011, 04:11:37 PM by chefducuisine »
e.oelberg
« Reply #13 on: May 05, 2011, 12:19:32 PM »
Nicholas:
I see, the size is what I liked so much about that trafo !!!
I'm going to post my very similar atempt too !
ioaudio
« Reply #14 on: May 05, 2011, 12:54:12 PM »
great stuff and nice pics!
I think the combination of the ballsy K47 with self biasing EF86 & matching transformer is a wise choice.
Did you experiment to find the value of the coupling cap?
chefducuisine
« Reply #15 on: May 05, 2011, 01:08:14 PM »
Max,
many thanks for the compliments - at least this is based on your Ideas... Many Thanks, again!!
I've experimented with the coupling cap  - 0,33uF is what I liked best.
Regards,
Chris
volker
« Reply #16 on: May 05, 2011, 06:50:03 PM »
Looks great Chris!
And nice to see another fellow Ulmer ;D. If you ever fancy a beer (or three),
I'm doing sound on most Mondays at the Sauschdall, just drop by.
Volker
chefducuisine
« Reply #17 on: May 10, 2011, 02:03:36 AM »
Hi Volker,
I've been there yesterday. Unfortunately you where not there.
As soon as time allows I will visit the 'Sauschdall' again...
Regards,
Chris
volker
« Reply #18 on: May 10, 2011, 06:01:06 AM »
Yes, somewhat ill at the moment... Sent you a PM!
Last post June 27, 2013, 02:16:51 AM
by zebra50
Last post January 10, 2011, 04:22:19 AM
by gary o
Last post May 08, 2012, 05:20:49 AM
by manulaudic
Last post August 22, 2018, 12:16:09 PM
by McIrish
