Adky said:.....it should be a 8ch ADC and 8ch DAC at the same time, with digital bypass, I am thinking about when you are not using the adat interface options you can actually use it as a line preamp as well?? :
Adky said:Is it like no matters how good the spec of the DAC or ADC chip I use , I am still running into the Wavefront bottle neck?
Adky said:Internal and external clock with BNC socket Use 89S52A, 74HCT4052, 74HC4040 this box will run up to 24bit 192K
gemini86 said:If you're using wavefronr ics anyway, just buy a behringer ad8000 and mod the crap out of it. 8 I/o and adat I/o. Tada, just saved you a ton of time.
