andyoh
500 modules in DBX 900 rack
« on: May 09, 2011, 10:55:50 AM »
Hi there.
First post here. I´ve searched for info on the possibility of putting 500 modules in a DBX 900 rack but not gotten any wiser. Being a DIY beginner it´s all a lot to take in concerning different builds and projects, but I´m usually a fast learner and from what I gather, it´s possible to do so. The only issue, as I see it at least (remember, I´m a newbie), is the difference in card length, and of course the pin-out. (ok, ok, there is a slight V difference too...) It should be possible to make an extension and wire it accordingly, am I right. Or am I totally off-track?
I´m sure someone has good intel on this.
Kindly, Andy
strangeandbouncy
Re: 500 modules in DBX 900 rack
« Reply #1 on: May 09, 2011, 11:03:20 AM »
  I am intending to try this myself. i am going to make extenders. Check the pin-outs, they are NOT the same. I cannot see why this shouldnt work, but I have not checked the max current draw per module yet.
   good luck,
     ANdyP
. . . . RUH ROH . . . . .
andyoh
« Reply #2 on: May 09, 2011, 11:26:41 AM »
Hi Andy :)
Thanks for the reply. I am aware of the pinout difference but that shouldn´t be a problem - found pinout charts on DBX homepage.
Please keep me posted on how it´s working out for you - I believe you will be faster since I first have to order and build myself a 500 module  :)
Andyoh
[silent:arts]
« Reply #3 on: May 09, 2011, 11:34:30 AM »
I have one 903 module on the way to me.
My guess from pictures is the depth will be a problem.
Will tell back once my module arrives.
andyoh
« Reply #4 on: May 09, 2011, 11:36:08 AM »
Fitting a 903 in a 500 rack will probably be impossible, but the other way around should work... Or???
Andy
moamps
« Reply #5 on: May 09, 2011, 05:24:40 PM »
DBX 900 rack doesn't provide the phantom power so, without mods, the standard 500 series mike preamps for condensers can't be used.
Regards,
Milan
DBX 900 rack
Started by Unbound « 1 2 » Drawing Board
Last post August 26, 2008, 01:26:32 PM
by sahib
Last post June 08, 2005, 03:54:21 PM
by SSLtech
Last post September 04, 2009, 03:47:12 PM
by Sleeper
Last post September 16, 2010, 11:50:47 PM
by ewlewl
