Poor Man's Pultec EQP1-A Build Support Thread
« on: May 08, 2011, 08:29:31 AM »
Place holder for answers to questions related to building the Poor Man's Pultec EQP1-A.
Edit:  Added BOM and other documentation info:
There is no specific BOM except the switches are laid out for Lorlin types or their equivalent. Below is a link to  the latest schematic. It shows component values for a series of recommended frequencies but there is no reason you cannot use your own and calculate the capacitor values using the spreadsheet I provided in the original thread. As far as component choice is concerned, a lot depends on what accuracy you want and hence what tolerance of components you will need. It also depends on what range of values of capacitor are available where you are.
http://www.ianbell.ukfsn.org/pics/PMEQP1-AMKII.png
Here is the corresponding list of calculated and recommended practical capacitor values:
http://www.ianbell.ukfsn.org/pics/CapValues.pdf
Edit: Here is the schematic showing how the Hi and Lo PCBs are wired together to make the complete EQ (except the 56K is actually on the PCB now):
http://www.ianbell.ukfsn.org/pics/wiringsm.jpeg
Now, that schematic assumes you put the lo cut capacitors in the C1 to C6 postitons on the PCB. Many people have put the boost capacitors in the C1 to C6 positions (I did myself). If you did this you need to wire up the two EQ PCBs accoring to this schematic:
http://www.ianbell.ukfsn.org/pics/alteq/hookupsm.jpg
Here is the PCB layout showing the component positions:
http://www.ianbell.ukfsn.org/pics/PMEQP1ApcbV4.png
And here is the system diagram showing how the EQ mates with the input transformer, an EQ In/OUT switch and the gain make up amplifier.
http://www.ianbell.ukfsn.org/pics/EQSystem.png
An finally here is a link to a circuit for a possible tube gain make up stage.
http://www.ianbell.ukfsn.org/pics/PMTGMsm.jpeg
Edit: plus the hookup diagram showing how all the various bits fit together is appended as a pdf file.
Edit: April 2012: And here is a link to a hookup that shows how to wire the EQ to the tube gain make up and PCB and its power supply:
http://www.ianbell.ukfsn.org/pics/alteq/2-wirescaled.jpeg
Edit: PLus here is the link to the BOM for the recommended design including the tube gain make up and its power supply:
http://www.ianbell.ukfsn.org/pics/alteq/partslist.xls
Edit Aug 2012. We now have the benefit of Chicago Dave's excellent colour hook up diagrams for the EQP1A and for the mid boost/cut add-on:
http://www.ianbell.ukfsn.org/EzTubeMixer/docs/PMEQP1A/DavesPMEQP-1A%20Hookup%20Diagram.pdf
http://www.ianbell.ukfsn.org/EzTubeMixer/docs/PMEQP1A/DavesPoor%20Mid%20Hookup.pdf
Thanks Dave.
« Last Edit: August 09, 2012, 04:57:52 PM by ruffrecords »
Re: Poor Man's Pultec EQP1-A Build Support Thread
« Reply #1 on: May 08, 2011, 11:53:52 AM »
Place holder for construction tips.
1. Fit resistors and capacitors to PCB first. If you fit the switch first it is very hard to support the caps while they are soldered in. I found this out the hard way.
2. Try to use 50V or 63V caps. 100V caps are fine but some WIMA 100V types are very fat even for quite small values.
3. Caps can be fitted to either side of the PCB. The PCB is laid out for two skinny caps per switch position. if you need to fit a fat one and a skinny one then fit the fat one on the rear of the PCB.
4. If you need to fit a fat cap at one of the switch positions where the caps are near the edge of the PCB then fit the fat cap on the inner of the two positions otherwise it will overlap the edge of the PCB and it may be more difficult to fit into a 1U high space.
5. Panasonic do a nice range of compact 5mm pitch 5% tolerance film caps.
http://uk.farnell.com/jsp/search/browse.jsp?N=500006+1000229+5700009+5156429+5087885+5586183+5087944&Ntk=PLS_MAN_BRAND_NAME&Ntt=panasonic&Ntx=&No=0&getResults=true&appliedparametrics=true&locale=en_UK&catalogId=&prevNValues=500006+1000229+5700009+5156429+5087885+5586183+5087944+5087494+5586078&filtersHidden=false&appliedHidden=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D500006%2B1000229%26Ntk%3DPLS_MAN_BRAND_NAME%26Ntt%3Dpanasonic%26Ntx%3D%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_UK%26catalogId%3D%26prevNValues%3D500006%2B1000229
« Last Edit: May 08, 2011, 01:42:34 PM by ruffrecords »
ej_whyte
« Reply #2 on: May 08, 2011, 12:41:19 PM »
Here are my stepped pot calcs, might be useful to have them in here.
« Reply #3 on: May 10, 2011, 12:07:04 PM »
Here is a snap of the Hi (left) and Lo (right) switch assemblies complete. What appear to be resistors on the Lo PCB are zero ohm resistors for the links.
ej_whyte
« Reply #4 on: May 10, 2011, 12:24:49 PM »
What about the small jumper next to the 56k resistor? i thought that had to be done on the low pcb?
« Reply #5 on: May 10, 2011, 02:41:44 PM »
You are right, it does. You may not be able to see it in the picture but what I did was simply use the leg of the resistor to make the link under the PCB.
« Reply #6 on: May 10, 2011, 05:26:07 PM »
I just noticed a potential error in wiring sketch I did (copied below). When I built the two PCBs I put the boost components in the C1 thru' C6 positions and the cut components in the C7 thru' C12 positions. If you do that and wire it up according to the sketch below it will not work properly because the Lo boost caps get connected to the lo cut pot and vice versa. I'll do an updated version and post it tomorrow if I can. In the meantime if you replace T1 and T2 with T3 and T4 and then replace T3 and T4 with T1 and T2 it should work fine.
« Reply #7 on: May 11, 2011, 09:24:29 AM »
Here is an updated version of the hook up diagram. I have also noted the position of the counter-clockwise setting (off) of each pot.
baadc0de
« Reply #8 on: May 11, 2011, 10:18:24 AM »
I followed a bit in the main thread that spawned this, but I wasn't entirely sure, so I'll ask here.. what about the inductor? I think there's a place for it and I see L1 populated on the PCB. I've built an ordinary EQP in the past and it had a multi-tapped inductors, so what's the function of this one here, can one omit it, what kind of value does/should it have, etc.?
Sorry if this is a really newb question, I guess it indicates just what a hack I am :D
« Reply #9 on: May 11, 2011, 11:38:27 AM »
It was put in as a bit of an after thought simply because there was space on the PCB for a small one and somebody asked if I would include it on the layout. It just allows a small inductor to be used at one frequency setting only. You don't need to fit it and you can just  short it out.
If you look half way down this page:
http://www.groupdiy.com/index.php?topic=43859.60
you will see what I said about possible inductor values.
« Last Edit: May 14, 2011, 07:21:25 AM by ruffrecords »
3nity
« Reply #10 on: May 12, 2011, 01:29:22 PM »
Got my boards.
Is there a specific Bom or are we looking at the schematic:
Thanks.
« Last Edit: May 12, 2011, 01:44:32 PM by 3nity »
Life is a path, death the destination.
« Reply #11 on: May 12, 2011, 04:13:26 PM »
Got my boards.
Is there a specific Bom or are we looking at the schematic.
Thanks.
There is no specific BOM except the switches are laid out for Lorlin types or their equivalent. Below is a link to  the latest schematic. It shows component values for a series of recommended frequencies but there is no reason you cannot use your own and calculate the capacitor values using the spreadsheet I provided in the original thread. As far as component choice is concerned, a lot depends on what accuracy you want and hence what tolerance of components you will need. it also depends on what range of values of capacitor are available where you are.
http://www.ianbell.ukfsn.org/pics/PMTGMsm.jpeghttp://
CJ
« Reply #12 on: May 12, 2011, 09:46:01 PM »
we have this Peerles S 217 D all blueprinted,
who needs one?
If I can't fix it, I can fix it so nobody else can!
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
shabtek
« Reply #13 on: May 12, 2011, 10:02:58 PM »
CJ!!!           I need 1.
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
buschfsu
« Reply #14 on: May 13, 2011, 09:08:22 AM »
CJ 2 plzzzzz
PRR said...
OHM'S LAW. Not as an abstract thing: you should be able to glance at a small circuit and "instantly" know I and V, the way a soccer player glances at the ball and knows the angle and kick
« Reply #15 on: May 13, 2011, 07:04:59 PM »
Here's a pic of my lash up prototype on the bench. I am pleased to say it appears to work as advertised. The Lo PCB is at the bottom. Notice the larger caps fitted to the rear of the PCB.
« Last Edit: May 13, 2011, 07:06:35 PM by ruffrecords »
gemini86
« Reply #16 on: May 13, 2011, 09:10:25 PM »
that's quite the mish-mash of pots you have there...
Just curious though, where does one get 470k/47k/4.7K pots in the US?
- Rodney
"...you better call Kenny Loggins, 'cause you're in the danger zone."
« Reply #17 on: May 14, 2011, 07:06:16 AM »
Someone else had this problem in the original thread. It seem 5K, 50K and 500K are more common in the USA so I would suggest you use those values and tweak the capacitor values accordingly. If you check the original thread you should find that the person who originally asked the question tweaked the spreadsheet for those values of pot in order to calculate new cap values. I promised to update the spreadsheet so you could feed in different pot values and I have now done this. Just for you I have set the initial values to 5k etc.  All you have to do is set the Hi Cut pot value and the spreadsheet calculates the other pot values and all the capacitor values (except for the inductor ones). If you set the Hi Cut pot to 1000 for example you get very close to the classic Pultec circuit.
For those interested in using the single inductor position, the spreadsheet now also includes a section that calculates the required L and series C values for a variety of frequencies for a Q of 0.6.
http://www.ianbell.ukfsn.org/pics/capcalc.xls
« Last Edit: May 14, 2011, 07:19:29 AM by ruffrecords »
baadc0de
« Reply #18 on: May 14, 2011, 10:09:35 AM »
Thanks Ian for doing this..
If I understand correctly, the inductor only kicks in at one specific frequency stop (probably the highest?) and if you populate it if you can then calculate an alternative capacitor for that stop and have a Q of 0.6 at that point?
« Reply #19 on: May 14, 2011, 10:45:03 AM »
That's right. I think it happens to be in the left most position of the switch so if you want to make it the highest frequency then your frequencies will have to increase as you switch anti-clockwise.
Last post September 12, 2017, 05:47:24 AM
by alexc
Last post July 07, 2008, 11:56:08 AM
by bodega
Last post August 04, 2016, 11:33:06 AM
by ViciusbeatZ
Last post August 09, 2013, 09:29:39 PM
by mikeyB
