Poor Man's Pultec EQP1-A Build Support Thread
dirtyhanfri said:
I think I don´t get it, should I geg a toroid transformer with 6.3v ac secondary? Then... 2 power inputs? One for the psu and one for the psu? Surely not.... But I don´t fully understand it.
Thanks for your patience
No problem. Both the 250V ac and the 6.3V ac should be supplied by secondary windings of a transformer. DO NOT UNDER ANY CIRCUMSTANCES CONNECT THE PSU DIRECTLY TO THE MAINS.
Suitable transformers are available from many suppliers and I am sure there will be one in Italy.
On another forum I have been helping someone from Italy design a tube mixer. I have emailed him and asked him if he will help you out. If he agrees I will PM you his email.
Ok, I´ ll get an old transformer I´ve got around and measure the secondarys current, if it´ s usable I´ ll go on, if not, I´ll look for a transformer in a local shop.
Any help will be welcome, but I think you believe I´m from Italy, actually I´m from Spain. But I´m really thankful of all your help.
I´ m gonna get the transformer and wire everything, get sure it looks ok and then plug it, I´ll be careful. Thanks
Oops, my mistake. Sorry about that. LOL
I have added to the first post in this thread an overall hookup diagram for the power supply, tube gain make up and EQ showing how one channel all fits together. I have used the pin names used on the tube gain make up PCb to hopefully avoid confusion and shown how screened cable should be used from the output of the EQ to the input of the gain make up amplifier. I repeat it here for convenience.
Edit: Corrected version attached..
  • PMEQP1Ahookup.pdf
Wrong Post Before
Thanks for the useful link Hank Dussen, I`ll get that transformer
Also I`ll get a pair of tube sockets, these seems to be ok, but I`d like to be sure
http://www.musikding.de/product_info.php/info/p1196_Socket-noval-print.html
They look exactly like the ones I use.
I have had several requests for a basic parts list for the poor man's Pultec EQP1A and the poor man's tube gain make up stage so I have put one together. Since people will be buying all over the world I have not specified part numbers but there should be enough description to find the right parts wherever you live. The only things not inlcuded are the input and output connectors, the EQ in/out switch and the Sowter output transformer. The EQ capacitors list is the smallest number for the suggested hi and lo  frequencies and I have shown the position of each on the PCBs.
http://www.ianbell.ukfsn.org/pics/alteq/partslist.xls
Have many people have completed this project? I saw lots of boards get snapped up, but not so many reports on the final product. :eek:
I'm finishing up a stereo unit, and I've used Lundahl 1521s on the input and then I've used the PPA I/O boards for the make up gain with JLM 99v opamps. I used polystyrene caps in the hi boost and whatever I could get my hands on for the other sections. (A mixture of the polys....prop.....ester.....styrenes.....)
The front panel is ugly at this stage, so no photos just yet, but I have to say that the hi boost on this eq is just lovely. :)
I've been inserting it on same vocal tracks (both mono & stereo) and I think it's gonna get used there a lot from now on.
Fantastic project :D :D
I know at least one group member has completed a project using them because he PM'd me some pics.
pics or it didn't happen....
:D
I plan on doing a p2p or 500 version in the future, but have other projects to complete first.
Hi everyone,
I'm starting to collect parts for a dual mono build and would like to order transformers (planning on going with Ian's tube makeup gain stage). In the interests of affordability, I'm thinking of these Edcors for the ins and outs:
http://www.edcorusa.com/products/156-xsm600-600.aspx
http://www.edcorusa.com/products/161-xsm10k-10k.aspx
There seems to be a wide range of opinion on these products. Anyone care to offer an opinion on how they might serve here?
For power, I'm thinking of this toroid from Antek (their 250V secondary model is out of stock - might this work instead?):
http://www.antekinc.com/details.php?p=638
Happy to entertain other options and would be curious to hear what North Americans have been using for powering their builds, and as alternatives to the Sowters for in and outs.
Ralph
rmaier said:
Hi everyone,
The 600:600 for the output has a primary inductance on only 3H. This is so low that the resultant  bass response will be both poor and distorted.
The 10K:10K for the input has a primary inductance of 25H which has an impedance of 10K at 64Hz. This means that as long as your source impedance is in fact 1K or less then this transformer will be fine at the input.  In fact it would probably do at the output too since it can take 50V rms which is +36dBu.
That should be fine. The tube gain make up stage is not particularly sensitive to HT voltage and the prototype was built with a mains transformer with a 240V ac secondary.
erikb1971 said:
It might be interesting for you pm-eqp1 people to check this thread and join the discussion: http://www.groupdiy.com/index.php?topic=45475.new;topicseen#new. Ian is having something nice up his sleeve again!
Well bang goes the idea of a stereo PM in a 1U case! :)  Well not really, but I was just working on a front panel design last night for my stereo version so will do that first. I have extra boards so may either do another stereo with valve make up gain (1st build is with PPA's doa make up) or possibly try this new 'enhanced' version. We are entering into the realms of it no longer being a poor man's Pultec though are we not?! :) Excuse my ignorance, but how much of a different 'flavour' would this add compared to the original eqp1? I suppose it would be a bit of an eqp1 and meq5 hybrid...good work anyway  and looking forward to the outcome :)
I found some time to (almost) finish mine.
I used JLM Dingos for I/O, I'm currently experimenting with different DOAs and transformers.
Needs some clean up here and there, but it works good.
