ruckus328
Thought I'd see what some thoughts are on this, I realize this might not be so black and white and subjective, but looking for any opinions on the matter. I'm fiddling with a couple compressor designs, and the dilemma has come up whether to electronically balance or use transformers on the inputs and outputs. It's modern in/out impedances I'm dealing with. I do want some color, and would prefer to put iron on only either the the input or output and electronically balance the other (via THAT 124X/164X or similar) just for cost/simplicity purposes, but the question then is - iron on the input or output? Are there generally any sonic benfits to one or the other? Any other pros/cons? Thanks.
