warpie said:... are these any better than the ALPS?
It's not for repair. It's a new PCB I'm making. However, it's personal project so maybe even a few of these will do the trick.If it is something new, I would suggest a right angle PCB approach.
Arno said:No idea about the dubbledeck switches, there's a good chance you need high qty order.
Don't know if it helps but Rapid sells the standard toneluck switches...
http://www.rapidonline.com/searchresults.aspx?style=0&kw=toneluck
Rob Flinn said:Arno said:No idea about the dubbledeck switches, there's a good chance you need high qty order.
Only if you buy 1000 at a time now. This changed from being able to buy individual switches about 1 month ago.
warpie said:Hi Brad, thanks for the offer. Are these switches compatible with toneluck (or ALPS) footprint?
How many poles are they?
If I had enough panel space I would use two different switches but unfortunately that's not an option in 1U rack.
warpie said:Rob Flinn said:Arno said:No idea about the dubbledeck switches, there's a good chance you need high qty order.
Yes, I noticed that although I think it applies only to 4pole. You can buy single 2 pole and 6 pole switches I think.
I need 4-pole but since I design the PCB I think I'll make a footprint for the 6 pole anyway.
My only problem is the 'piggythingie' switch that's impossible to find. I was thinking to do somethingt similar to what MagnetoSound described but I'm a bit concerned about the stability.
