What oil for my Grandfather clock ?
Rob Flinn
Between Sussex, UK & Aude, France.
I had to move my Grandfather clock the other day & since then the hourly chimes have stopped working.  It sounds like they are going to happen, but they don't.  The quarterly chimes are fine.  I suspect that a little oiling might sort things out but I'm never sure what oil to use.
Anybody into clocks ?
Ironically, my grandfather would use Marvel Mystery Oil!
Just found this
http://www.youtube.com/watch?v=GaiLSVOxMkc
It seems that the oil is held in place by surface tension, & too much oil can result in the surface tension being broken & 100% of the oil draining away.  I'm tempted to take it to a specialist.  My Grandad left me the clock in his will, so I need to get this right ....
Lack of oil won't stop a clock.
It will go more centuries with a super-light clean oil, but it doesn't need oil to run.
You jarred something out of place.
Take a VERY careful look. Be even more careful about disturbing anything.
CALL the specialist first.
He may even know what you did and tell you how to right it.
If it has to "go in", since it didn't like your last move, obviously you shouldn't do that without a specialist telling you how to move it without further damage.
Rob,
You need to get in touch with 'Chronos'.
Although a model engineering supplier, they specialise as the name suggests, in all things
time piece related.  www.chronos.ltd.uk
Frank B.
