The problem is complex. And the origin is I don’t understand why the 990 module is much much much better than another thing.
I read in some places that the secret is, plus other aspects of course, the MJE181 / MJE171 pair, because it’s bigger than the end of a conventional OPA: “high-power output transistors are fully optimized for they unique and very different requirements” (textual John Hardy datasheets). Well, if I assume that is necessary a big end for “quasi esoteric” aspects, I can use a power IC….!
But I look a 990 schematic and is very similar than a 30 years little power amplifiers, and very similar than IC power amplifiers with differential gain stage front end, (with symmetrical power supply).
OK..., its true…, the power IC datasheets don’t advice les than 20dB gain, and a maximum is no specified (it’s not its work) but I think is 35 or 40 dB maximum for stability. But… I can use another 5534, OPA602 or other AOP step.
And the 990 costs the same than one hundred 5534….
I have a lot of doubts:
1.- ¿Why the 990 is much much much much better than another things?
2.- ¿Why (as I Know, I can be wrong) the most expensive microphone amplifiers use today that technology, (and with input and output transformers)?.
3.- ¿Why the 990 is better than another thinks, and its schematic is similar than a 25 or 30 years old discrete little power amplifiers with differential gain stage front end?.
4.- ¿Why the SSM2019 or derivates are the worst thing in the world.?
5.- Why the cheap is worst and the expensive is good?
Miquel
