Preamp cuts out at high gain
Ptownkid
Ajax, Ontario, Canada
I'm racking 8 q8 micpre cards for a client and I'm getting something I'm not familiar with...at about 3/4 gain, it abruptly goes silent and a little above that it starts to crackle if you make noise, and a little above that it makes all sorts of alien noises...
There's 8 channels of ssm2015 based pres, with 8 TL072 balancing cards...I'm using a 50VA xfmr, (36VCT @ 1.39A). Even when only one card is hooked up it does this, and 2 of the 8 don't exhibit this behaviour.
Any ideas?
Not sure about the gain set cap...looking at the datasheet right now. These are supposedly "known working" cards from a westar console. Just using a sm58 for testing.
They use a resistor to set gain I believe.
Sounds like they are possibly oscillating.
But that is strange cause they seem like stable chips.
Maybe they are touchy on how they are grounded.
Also have you isolated the problem to the ssm chips?
My first thought was also oscillation...going to check that in the morning. Is there a specific cap that takes care of that, my knowledge in this area is limited...
http://www.ka-electronics.com/images/SSM/SSM2015.pdf
Any ideas?
Transformerless?  Leaky Phantom blocking caps?
Bruno2000
Generally higher gain should be more resistant to oscillation as the NF is padded down, but not that topology, where closed loop gain interacts with open loop gain so remains relatively constant.
One thought, if there is a DC issue, the higher gain could be driving the output into saturation at one rail? While symptoms do sound like oscillation.
Also check that the compensation caps are correct for the bias current and in place.
As it turns out...it really is all 8 channels, just that two of them only exhibit the behaviour when gain is all the way up and the pad off.
John...what do you mean by DC issue? They are all getting +/-18V
are the 2 physically farther away from the power supply? Maybe the rails need to be reinforced?
Glad your getting it worked out!
If there is a DC voltage present across the input, as the gain gets turned up that DC times the gain could exceed the rail voltage... Not common but a possible fault.
Maybe look at pin voltages between good/bad channels. Or with gain low/hi.
are there dc blocking caps between the pre output and your balancer? Is there DC there when you crank the gain? it could be slamming the balancer with DC and that's no bueno.
DC blocking caps would be used just in case there's any DC offset in the system.
Their value will be based on the input impedance of the next stage... As it'll create a high pass filter.
the larger the value, the closer to DC you can move the -3dB high pass filter point.
However, other's might comment on the side effects.
Good luck with this. I'm watching to see what the resolution is.
So I experimented with various DC blocking caps between the output of the preamp and input of the balancing circuit with no real change in result.
Next?
Here's the pre http://www.mediafire.com/?dgb7oda55ijlk4d
There's already a 100uF cap in the schem. That should take care of any bias.
Sounds like the issue is in your differental line driver. Have you tried a single chip line driver? Such as the drv134/5?
Not yet...I was hoping to solve it using the existing pcbs and parts. I'm going to move on to the THAT chip or TI chip soon, but it means that my customer will have to pay an extra $5 per channel and I'll have to eat the cost of the tl072 pcbs and parts...
