stickjam
I'm looking to build a preamp for transfer/restoration work from vinyl to DAW--from a Stanton 681EEEmk3 to balanced +4dBu. I would like something different from the run of the mill phono amp. One feature I need is the ability to switch the RIAA EQ on and off. I've found click/pop removal is easier sometimes if the noise signal isn't distorted by the EQ--I add the RIAA curve after the fact with a parametric plugin. Sonically I'm looking for something really clean and musical--what a really good pre does for a mic.
My thought is to adapt a mic pre design, modifying the input to properly match a moving-iron cartridge. Then add a bypassable RIAA EQ and a balanced output section.
Does this sound like a worthwhile endeavor? Which of the regularly DIY-ed pres might be a good starting point? (The Stanton 681EEEmk3 already has a warm character in and of itself, BTW.) Any idea how to match an input to the cartridge instead of a mic? Any EQ and balancing recommendations? (On the latter, I stumbled upon a sleeve of Burr-Brown DRV-134A--any good?)
I've finished the physical studio DIY--the siren call of the soldering iron beckons now! :grin: Happy 05 and thanks in advance for any input. :sam: :sam:
--Bob
--Bob
