i have a TAB V72 with higher than expected hum in the output noise floor. I put the Tubes which curiously are unlabelled into the tube tester and they showed a heater cathode leakage of the order of 2meg ohm. to prove a point I the subbed in a pair of NOS telefunken EF804S into the V72 and all hum on the output sunk below the white noise floor.
I'm now curious about methods that might reduce the C-H leakage in the original tubes as their other characteristics measure fine. I suspect these tubes might be vanilla EF804. So far i've tried pushing them in the tube tester at a 10volt heater voltage with no HT for a few hours and that has dropped the leakage down to better than 10meg....but feels a bit scary. Anyone got any thoughts on other "rejuvination" processes?
