Thanks for the answers
I can be wrong, really, but I'm sure the problem is the shield, because moving the transformer (well, the PCB that contains the transformer), toward or away from possible interference sources, the hum vary (it’s like a funny game….)
In really, I am measuring output preamplifier noise at worst case, ergo at maximum preamplifier gain with a high sensitivity amplifier, but is the common studio test, not the normal operation of course.
For the measurement I use a really low noise 100x preamplifier (without transformers jejeje) which I use only for this application (the power supply is batteries to avoid ground loops) and I can measure uV easily, but… connecting the preamplifier output to a power amplifier with a high gain, the hummmmm is clearly audible. (I have a special battery powered amplifier that it provides 1W output with only 20mV balanced input at maximum gain, very interesting tool to investigate noise).
Noise sources examples:
A big not toroidal transformer (from a bench DC power supply) has a measurable effect at about 30 cm away.
An AC power line (just under the bench wood, my God…) has a measurable effect at 5 or 10 cm.
Really, you can say…: if you haven’t mains transformers near, or no AC near, no problem, but I think the transformer electromagnetic shield should be better.
Finally I think if Jensen makes transformers for special situations (expensive of course), I think that situation exists for all manufacturers.
I confess that maybe I'm too strict
Saludos cordials desde España,
