Hi all,
I recently acquired a pair of Studer 169 10 channel 2 bus consoles. One of them has an optional coupling board installed which should allow me to link the 2 consoles together for 20 input operation. I haven't been able to find any info on the 'net on this and the manual only gives a Studer part number for the cable required for this (1.169.989).
One end of the cable uses a standard 50pin DSub connector but the coupling print itself uses a 10-pin connector that I haven't been able to ID.
Here's a picture:
It's about 15mm in diameter.
Does anyone know this connector?
Also, does anyone have any experience using a pair of linked 169 consoles? Did everything work as expected? (I'm really hoping to replace my current Tascam m520 setup with this).
Thanks in advance for any help!
