Looks very nice! Need stereo link switch, +1.
If the GR meter circuit replaced with op-amp, why not replace detector circuit
(4 transistors, Q12...15 ref to 1176 schem) to 2 opamps+3 resistors...
This way, quad opamp will serve output meter rectifier, GR circuit, and detector. BTW, it will have same behavior as origin.
how does this compare to igor's F76?
Let's do it! Anyone?
As I can see, nice design, nice meter, nice knobs; should be fine if done good.
I avoided the use of DC/DC converter in 51X-F76, and this "output amp-trafo option" is impossible in my variant
If replacing the DC/DC converter to "analog" +30/-10 power supply leaves same signal to noise, I'd say, really cool.
So, we have an options, more options = more cool, the rest is the matter of taste.
Keep rockin! DIY rules.
