horvitz
My 550A Project
« on: July 29, 2011, 12:03:21 PM »
So I was going to come up with some cheeky subject but I thought there will be plenty of time for that later.
At any rate, I've been slaving away for quite a while now on reproducing the "it'll never be done" 550A using standard catalog switches from Grayhill.  The frequency selection was really the tricky bit and I had to jam 104 caps in there to get it right, but it does the trick!  I'm pleased to say that I've had some great success and with the exception of chasing some small bugs and a couple of mechanical items, everything works very well!
I'll post some nice traces in a little bit, but I wanted to get some pics of the unit up.  There's still work to be done, but I'm so close I couldn't resist sharing  ;D ;D
Slightly rough front panel.  I need a new name.. TB55A isn't doing it for me.  Sick of the Kilo knobs as well, but "that's not important right now" (ala Airplane!).  Gives an idea of the operation.
The fit together.  Once I get my proper front panel, there will be a standoff between the top and bottom boards with a nylon screw on top.  That nylon screw will be the tallest part of the board (at exactly 1.49") and should protect us against any naughty neighbors who might intrude on our space and ground out any of the stuff on the filter board since it really is close to the top (side?).
Oh, and big thanks to Papa Steiger for looking over my shoulder a bit and giving me some proper nudges here and there  :D
More to come..
  Brian
Re: My 550A Project
« Reply #1 on: July 29, 2011, 12:05:39 PM »
Wow, very nice work. Congrats and well done on this brave project.
Rybow
Re: My 550A Project
« Reply #2 on: July 29, 2011, 12:11:26 PM »
Wow! That looks great man. Good work. That's a whole lot of caps on there too. Looking forward to seeing your finished module!
dmp
Re: My 550A Project
« Reply #3 on: July 29, 2011, 12:17:21 PM »
Awesome. Why so many caps? The original schematic shows like 30-40?
horvitz
Re: My 550A Project
« Reply #4 on: July 29, 2011, 12:29:41 PM »
Thanks, guys.  Been a long road for sure.
And Dan, had to use all those caps to make up for not having the custom switches.  True there are only 40 caps in the original but many get put in parallel depending upon the switch position to make different values.  Also, wanting to use the WIMAs made it even worse since they don't have as many available values as some of the others.  Recognize some of those switches? :)
jsteiger
Re: My 550A Project
« Reply #5 on: July 29, 2011, 12:30:09 PM »
Like I mentioned on FB Brian, you are now king of the Lab!  ;D
I know it was more of a personal quest and had nothing to do with being king, but my hat is off to you! Your project looks outstanding!!
Nothing like 104 caps to get you tired of soldering a 104 caps!!
Best, Jeff
Visit the CAPI store at http://www.capi-gear.com
CAPI is not affiliated with, endorsed by, or sponsored by API.
dandeurloo
Re: My 550A Project
« Reply #6 on: July 29, 2011, 12:56:09 PM »
wow, how does it sound?
PROFESSIONAL CHASSIS AND FRONT PANELS FOR DIY PROJECTS: WWW.COLLECTIVECASES.COM
Dan Deurloo
www.collectivecases.com
www.risendrums.com
dmp
Re: My 550A Project
« Reply #7 on: July 29, 2011, 01:12:39 PM »
Yes, glad you could use them!
mulletchuck
Re: My 550A Project
« Reply #8 on: July 29, 2011, 01:27:42 PM »
wow that is awesome.  now you just need to provide a complete kit, and do the 550B next!
www.youtube.com/mulletchuck for all my recordings
horvitz
Re: My 550A Project
« Reply #9 on: July 29, 2011, 01:29:19 PM »
Man, you said it Jeff!  This thing takes a looong time to build.  Very easy to put something in the wrong place, too.  Definitely a project for the patient and careful.
Dan, a little to early yet for listening impressions.  I've done some trials and I think it's pretty sweet!  Of course I might be slightly biased.  My next build should really be as close to the finished unit as it needs to be and I'll probably do two.  I'd like to get those out to some other more experienced ears for feedback.
[silent:arts]
Re: My 550A Project
« Reply #10 on: July 29, 2011, 01:37:58 PM »
wow ...
... speechless
dissonantstring
Re: My 550A Project
« Reply #11 on: July 29, 2011, 01:48:42 PM »
wow ...
... speechless
+1  very impressed with your tenacity brian!  looking forward to listening impressions.
best,
grant
jsteiger
Re: My 550A Project
« Reply #12 on: July 29, 2011, 02:06:58 PM »
... speechless
I will help with one thing I forgot to mention earlier. Nice job on adding the card edge for the extra 51x pins. Nice to have for alignment and easy to trim off if not needed!  ;)
horvitz
Re: My 550A Project
« Reply #13 on: July 29, 2011, 02:16:51 PM »
Heck yeah!  Gotta think of my 51x brethren.  ;D
jsteiger
Re: My 550A Project
« Reply #14 on: July 29, 2011, 02:29:16 PM »
If it sounds like the sweeps I have seen look, the I'd say Brian has hit a home run.
horvitz
Re: My 550A Project
« Reply #15 on: July 29, 2011, 05:25:42 PM »
And some of those sweeps right here.  Mine side-by-side with a vintage A as indicated with different gain settings.
Shelf - Shelf
50Hz - .8K - 10K
100Hz - 3K - 15K Shelf
Re: My 550A Project
« Reply #16 on: July 29, 2011, 05:47:58 PM »
Great job Brian..... a braver man than I.
http://www.lazpro.com
I reserve the right to not sell to idiots
kishibashi
Re: My 550A Project
« Reply #17 on: July 29, 2011, 06:41:57 PM »
This is amazing! Congrats! Can't wait to hear some comparisons!
creal
Re: My 550A Project
« Reply #18 on: July 29, 2011, 06:46:26 PM »
Congratulation for this nice API eq.
your baby looks very good. :P
I hope find a kit in the white Maket soon
Cyril
zayance
Re: My 550A Project
« Reply #19 on: July 29, 2011, 06:49:40 PM »
Wow, we're getting some summer 500 Stuff festival in Prodigy, who's next?
i'll have a glass of Champagne  8) 8) :)
Last post June 23, 2004, 04:42:37 PM
by Bo Hansen
Last post June 28, 2004, 03:14:37 PM
by ytrehalf
Last post November 02, 2004, 01:36:51 AM
by CJ
Last post June 25, 2005, 05:42:31 AM
by laitue5
