ruckus328
Hey guys, once again the lovely fleet of "professional" engineers here have left me hanging, so once again I come to the board for some real answers ;D
I'm trying to better understand the math behind calculating attack & release times, it seems I'm overlooking something, as my time constant (t) calculations don't end up with the real world results. The results are almost always at some multiple of (t), Am I missing something? Or are the attack & release times a total approximation? Way I understand it, changing attack time will actually alter release time as well, and vice-a-versa, because of R-C value interaction. Specificially what I'm trying to do here is manipulate the attack and release times on the talkback compressor, though this would apply to anything really, and rather than just twiddle a pot to see what happens, I'd like to take a more scientific approach.
Below is a pic taken from the SSL comp (Set to 4:1 Ratio, 30mS Attack, 100mS Release). Since Attack/Release times are known for the given Res/Cap values, figured it would be a good example to analyze.
As I understand it, Attack is calculated using parallel equivalent of R1 & R2 & R13 * C1. So this would give me a result of 71K * 0.47uF = 33mS. OK, that works out.
However, changing R1 to 82K for a 10mS Attack time would give me: 44K * .47uF = 20mS. Is that right? If not, then what am I missing?
Looking at release time (supposedly 100mS) of the attached pic, as I understand it R1 is not taken into equation since discharge path of C1 is through R2 & R13, so simple t equation would give me about 46mS, which is about 1/2t. So once again, the math doesn't add up.
Thanks in advance for any help.
