ilfungo
Re: SSL 4000 EQ
« Reply #280 on: June 03, 2017, 01:51:33 PM »
Thanks Lagrange!!!
Re: SSL 4000 EQ
« Reply #281 on: November 10, 2017, 04:44:19 AM »
Can someone repost the latest BOM for the RS-82E02-Q so I can start a new winter project? ;-) PCB's need a new life :)
Thanks! <3
www.kontrast.in - I make websites and stores online.
Whoops
Re: SSL 4000 EQ
« Reply #282 on: November 10, 2017, 02:43:49 PM »
Thanks! <3
pm me your email, I send you the docs I have.
Although I don't have a BOM
Re: SSL 4000 EQ
« Reply #283 on: November 10, 2017, 06:29:28 PM »
 8) Thanks
tata
Re: SSL 4000 EQ
« Reply #284 on: November 19, 2017, 11:03:00 AM »
im finishing the 1st build of my 5 EQs soon, and id like to make sure about the the Q adjust correction.
so for proper function of the Q we need to wire the 1st deck of the dual A10k potentiometers' pin 1 and 3 in reverse? (compared to the PCB pins)
thank you!
Vac11
Re: SSL 4000 EQ
« Reply #285 on: November 19, 2017, 11:13:13 AM »
thank you!
Yes, that is correct...
tata
Re: SSL 4000 EQ
« Reply #286 on: November 19, 2017, 11:24:36 AM »
thanks Milan,
then im heating up my desoldering station to remove those pots from the PCB.. :D
btw i bought 50pcs of (mini, blue) dualC50k pots from AliExpress, they look totally OK so far. hopefully they will work OK too.
tata
Re: SSL 4000 EQ
« Reply #287 on: November 19, 2017, 11:35:52 AM »
its a bit sad to realize that some extra work is needed to get it racked with the out-of-PCB pots..
my FREQ. pots have 2.54mm pins, so wont fit the PCB. the Q pots must be corrected - so cant be populated on the PCB. GAIN pot is the 3rd deck, so wont fit (easily) the front panel as PCB support.
the switches make 0 support, so the PCBs must be carefully fixed in the rack in some ways.
SIXTYNINER
Re: SSL 4000 EQ
« Reply #288 on: March 06, 2018, 11:44:39 AM »
it would be cool if possible to put a stereo eq inside 2U rack unit together with GSSL comp
>>" 1 Picture say what billions words cannot "<< - >>"SMD Kill the DIY STAR"<<
Why in the  forum  if no share
SIXTYNINER
Re: SSL 4000 EQ
« Reply #289 on: March 06, 2018, 04:53:15 PM »
Also flip the pcb for have frequency sequence ,
low at left side to hi in the right side of panel
any more pcb available ?
SIXTYNINER
Re: SSL 4000 EQ
« Reply #290 on: March 06, 2018, 05:33:13 PM »
Here are the gerbers .
There are a few for the taking.  Though not all have been tested, Nor are they supported.  Schematics and a board image is included in the zipped folders.
https://drive.google.com/folderview?id=0B5TzR7Ho7CD9fnVRY2hOSU9CaGs0anAwdVdVMmJKOXNUX1VOcHg4c1hqalkwOWtFbXFHV1U&usp=sharing
only for let you know that the ssl 4000 eq gerbers file is not at the link
r2d2
Re: SSL 4000 EQ
« Reply #291 on: March 08, 2018, 08:41:14 AM »
Sorry I meant "triple gang" concentric. This style:
50KC is value from the "original" schematic (see pdf in attachement), in BOM is 47KC cause these triple gang concentric pots were stock in AML eshop. Value 47K is OK and it will not create any problem in this SSL EQ. The same is 22KB (in BOM) vs. 25KB (in origo shem).
Footprint on the pcb is designed for triple gang concentric pot. But you can use instead of triplegang concentric pot 1x dualgang pot (50KC for frequency) and one singel gang pot (25KB for gain) on this positions... For the Q pot is footprint made for different types of potentiometer legs spacing (Therefore, there is a 9 holes on pcb, but in reality you use only 6 holes).
In "original" schem is:
frequency - dual gang 50K anti log (or reverse log or  negativ log or "C") - 4x per one chanel - you can use 16mm 47KC dual gang from AML
Q - dual gang 10K logaritmic (or audio or "A") - 2x per one chanel - no problem with this pot, you can find it on ebay, or aliexpress,...
Gain adjust - 25K linear (or "B") - 4x per one chanel - you can use 22KB singel gang with center O position from AML
I didnt use concentric pots on my build. I used on one chanel 4x 50KC dual gang pots for frequency, 4x 25KB singel gang pot (or rotary switch with resistor chain) for GAIN +- and dual gang 10KA for Q adjusting (these pots you can find on ebay, or mouser...).
Hope this helps! (?)
Hello "Vac11" ,
do you share some info about frequency step selectors?
thanks
..... Cracking D.Vader Firewall ...  II-)
Vac11
Re: SSL 4000 EQ
« Reply #292 on: March 08, 2018, 09:01:04 AM »
I didnt use frequency selector (or stepped switches if I understand you corectly) in my build. I used standard potentiometers....
M.
r2d2
Re: SSL 4000 EQ
« Reply #293 on: March 08, 2018, 09:20:17 AM »
M.
i mean that showed on the images in the upper post
it is not made by you ?
Vac11
Re: SSL 4000 EQ
« Reply #294 on: March 08, 2018, 09:41:28 AM »
Oh, ok...it is +- 15dB gain switch...
Its only the lorlin rotary switch with 10 pcs of 2k49 resistors...
For 11 steps (5steps-center position-5steps) you need 10 resistors.
Geniue SSL EQ use 25KB (linear) potentiometer for gain.... So 25K/10 steps = 2K5 per one step.
You connect one cable on resistors chains start, other on resistors chains finish and one last cable on switches pole...
Hope this help you...
r2d2
Re: SSL 4000 EQ
« Reply #295 on: March 08, 2018, 10:27:20 AM »
…..Hope this help you...
yes of course , and not only me….
have you done with rotary switch , because not easy get the proper pots ?
more thanks
Vac11
Re: SSL 4000 EQ
« Reply #296 on: March 09, 2018, 01:43:04 AM »
I havent... Sorry. I used standard potentiometers for Q and for frequency sweeping...
Jordan
Re: SSL 4000 EQ
« Reply #297 on: February 07, 2019, 05:37:13 AM »
Hello everyone,
I am looking to download Casey's schema in a correct quality. Can someone help me?
Thank you.
Jordan
Re: SSL 4000 EQ
« Reply #298 on: March 19, 2019, 01:09:48 PM »
A friend asked me recently to make couple of those so I redrew the PCBs to fit parts of my choice namely the pots which I got from Aliexpress. A 20-25k center tapped pot is virtually unobtainium but you can find several types of dual gang 50k linear center tapped pots (with 40 steps) which when connected in parallel make a descent 20-25k mono center tapped pot. The 50k reverse log pots are also from Ali.
Other fixes included swapping the Q pots terminals as noted earlier in the thread and make the unit ON when power button is pressed in but relay is not activated (it's in normally closed state).
« Last Edit: March 19, 2019, 01:14:55 PM by MerlynMetal »
Re: SSL 4000 EQ
« Reply #299 on: March 19, 2019, 01:10:27 PM »
One more from the back:
Last post November 01, 2004, 04:59:54 PM
by owel
Last post December 29, 2004, 05:50:22 PM
by nrgrecording
Last post May 29, 2005, 07:06:57 AM
by bovox
Last post March 06, 2010, 04:38:44 PM
by sodderboy
