missing another 24V psu (and probably/maybe an additional +48V supply for phantom powered mics). Your 24V psu for your neves probably is a single rail psu. These 500/51x modules are powered by dual rails, IE +24V and -24V with a 0V reference voltage in between, that is 48V between these +/-rails, if it is a +/-24V supply. These rails can get regulated down to maybe +/-16V for the api500 format 15-pin cards by the RACK-IT.atticmike said:So this would basically be a smart move if I had psu that runs at 24V (running two neves) and I want to run two additional 500 modules (ssl 9k) in the same box with the respective voltage, which then would be regulated down to 16V at igor's ps?
gar381 said:http://classicapi.com/catalog/product_info.php?cPath=84_86&products_id=148
Ive just realised, this looks a bit like Radial Workhorse Powerstrip.Igor said:Mm yap. Rackit! 3
I second that motion!Finlaywatt said:Is it still possible to get hold of these? Had a look on the store and couldn't see anything.
