You forgot "more expensive" is better, and lots of hand labor is always more expensive...
Man that is right on, I may have to steal that!Emperor Tomato Ketchup said:The rules of "Tone" for guitarists:
1. Older is always better.
2. Hand made is always better.
3. Obscurity sounds better (ever hear a 1940's Teletubby 4AQ7A tube in a phase inverter? To die for...)
4. High price sounds better.
5. "American made" sounds better.
6. Rarity sounds better (preferably prototypes or one-offs, but <100 limited editions are acceptable).
7. None of the above matters because "Tone" is entirely in the player's fingers.
fazer said:I would rather work on a PTP than a PCB. But from a design stand point, the myth starts with other things.
Ken Fisher built Trainwreck amps. They are kind of a JCM 800 meets Fender with more gain. He used PTP construction and solid core wire. Most reproductions do not have the sound of his fine tuned designs. One of the tricks with these amps is that the solid core wire allowed him to bend wires around and they stayed in place which would then not have parasitic oscillation problems due to the high gain instability and cross coupling of circuits and layout.
When he would get done tuning them they were fantastic sounding amps that would allow the guitar player to have great touch sensitivity. The volume on the guitar could be turned down for clean sounds and up for roaring solos. There are YouTube videos showing this.
The second amp is even older. Blackface fenders had a special layout of the wiring for a great no parasitic amp that had a great clean and overdriven sound as well. The amps are also very touch sensitive. Leo Fender had people trained to do the layout just right for a great tone from those amps.
When CBS bought the amp company, they increased production and did not pay attention to the layout and wound up putting caps all over the place to roll off the RF pickup of a poor absent minded lay-in of the wiring. It was basically a blackface amp but now with all kinds of problems due to how the wires were routed somewhat random.
Its like building hot rods. You may be able to drive it if you built it but anyone else tries to build it and gets the layout wrong, you wind up in the ditch.
That said, time moves on . Once a PCB goes through revisions, it may get there but you would never be able to bend wires around like Howard Dumble did on his amps, until they performed perfect for the likes of Robin Ford and others.
Just a different look at amp builds.
I would assume the same is true of PTP Microphone preamp layouts when they approach 70db of gain or better for ribbon microphones. You simply route the wiring in the high gain areas to reduce parasitic problems.
exactly, and you don't have to worry about the tech who is replacing a pot 5 years down the track, who bends all the wires in doing so!Andy Peters said:All of the above, of course, is an argument for PCBs. Once you get the layout correct, you can be sure that the "lay of the wires" will never change.
-a
You missed the symbolic meaning of the sentence ...volker said:tv said:That's because Real men use Vero.deuce42 said:Why do guitar forums have these PCB vs PTP debates?
For high voltage? Well, to each his own... Also, at 1,xmm thickness and the complete surface perforated with holes, way too fragile for my taste.
fazer said:Ken Fisher built Trainwreck amps. They are kind of a JCM 800 meets Fender with more gain. He used PTP construction and solid core wire. Most reproductions do not have the sound of his fine tuned designs. One of the tricks with these amps is that the solid core wire allowed him to bend wires around and they stayed in place which would then not have parasitic oscillation problems due to the high gain instability and cross coupling of circuits and layout.
