Got the top caps ,valves,valve sockets & a choke from a chap near you Robin in Sussex Billingshurst in fact perhaps you know of him his name is Phil not sure his company name, think I had the last 2 top caps at the time one is 2nd hand, his prices are good too, ive bent his ear quite a lot over this BA project, he has been very helpfull, I can give you his details if you need them, Be nice to put bit of trade his way,having bit of an issue with the top caps at the mo as it goes, moving them while the BA is on while playing a walkman thru it upsets the voltages on the 6J7s pin 3s anodes is it? I would of thought both anodes volts should be the same, kind of balanced & sometimes they are 272 volts in fact but then no audio passes its like they cancel each other out & when top caps are wiggled audio blasts thru but voltages read roughly 104V on one anode & 57V on other any ideas or is this right or is it coz I have no inta tran in place?
Cheers?? Gary O.
