Fishing in polluted sea in Haifa.... NO!!!! On the north of Israel there are few small rivers dedicated for fishing, same, not best fun.
But for sure, some good pubs, YES!!!!!!
Attached is the stoppin picture, copy pasted from F-76
Hey Igor,
1- Do I need to cut pins 17/18 of card edge connector?
No
a- I would like use -/+24V in the furture! so can I just jump jp1/jp 2 instead of cutting pins 17/18?
He, yep. Just tell to people you using
API opamps on +/-16V, it is bit different! Yes, in this case, jump +16 to +24; same jump -16 to -24,
use ONLY +/-16V power supply AND DO NOT INSTALL ANY REGULATORS (317/337) on Rackit!!!!!!
+/-16V power supply should be connected to +/-24V rails of rackit.
In future, if you like to change it to 51X format: remove all +/-16V discrete opamps;
balanced line receiver feed from +/-16 anyway; put +/-24V opamps, 317/337 to rackit, DISCONNECT 16 and 24V rails, feed +/-24V supply to +/-24V rails of rackit.
b- But I use -/+16 V for the moment! PSU out is ok! so I got -/+ 16V and when I connect PSU to the board than R1/R2/R3/R6 are smoking
? do you have any idea?
Remove op-amps, all IC's, recheck; this way we can know if the prob is reversed power supply cap, short or discrete opamps.
3-On the rackit; What I need to do with three pins: Outs G and insG? and the Link conncetion must be connected how?
OUTG and INPG are pins 1 of XLR's. Depending on grounding scheme, tie them to agnd (circuit analog ground) or case.
For me, agnd worked best.
LINK - do nothing, it used for compressors only to tie detectors together.
