Im trying to get a 38, that i recently bought, running. It was transporting tape before i bought it. After i replaced the belt i found the capstan not moving, However the shaft rotates nicely by hand.
The voltage to the motor is about 34v.
Inside the motor the resistor has gone char coal and measures about 6kohm.
i replaced the part with a 2,2uH inductor. after doing so and cleaning surfaces, alot of stuff started breaking down.two of thoose small plates sitting around the shaft that connects with the arms got loose and the plate that all the soldering conections are on started falling apart here and there.
shiiiiiit , i thought. but made a try anyway to have it repaired. cleand and glued the plates back by hand and made som ugly soldering job. believe it or not but the motor is now running!!! how ong is the question.
