so TK up in Olytown WA wants a dual channel amp for keyboards, bass, git fiddle,
always wanted to build a Ampeg B15 Portaflex, so i took some parts up there and built it in his garage, only problem was i had only 1 output trans.
but i did have a hammond pwr trans from an LA2 project,
guess waht, it works great!
ratio is way off, using centertapped sec as pri, and the 6.3 winding as the spk winding.
so if you need a 6l6 output for cheap, jus sayin,
here is the circuit and here is the chassis, it sounds fantastic,
no 12ax7 stuff, all octals, 6sl7, 6sn7 as splitter to knock down gain for keys, which is also a total mismact, go figure,
