MS, MIX (Parallel), Level.... Utility Feed and MS/Mix/Bypass Board.
Israel
Some days ago, I was asked to build 4 Utility Feeds, used in K-1 Mastering Transfer chain,
each UF in 1RU, very simple format, and very fast.
Utility Feed is my idea to build all necessary processing like:
Pre/Post Device Level, MS, MIX (or dry/wet, parallel) across the insert device.
So, here we go.
Today I ordered 5 prototype MS/MIX/Bypass boards....
Well, this thing is quite DIY-friendly. If interested in progress, I will post here. Questions welcome.
Utility feed with digital control used in K-1:
Front panel design for simple Utility Feed, in 1RU, mind, all controls can be in steps:
Utility Feed Signal Flow:
MS/MIX/Bypass board:
To make one utility feed, the receipt is:
- One MS/MIX/Bypass board;
- One Pre/Post Level Board.
The Pre/Post Level Board almost finished (the easy part), here is its signal flow:
