jsefer
D-AOC Porn Inside [More Pics Added]
« on: September 26, 2011, 01:56:05 AM »
Just finished my unit this weekend, and aboslulely love it.
This is my 2nd DIY and I must say Im happy both my builds came out perfect, with little troubleshooting to be done.
Stats:
Cinemag CMLI-10/600B inputs
Cinemag CM-9589L outputs
Telefunken Tubes
ecc801s
ecc82
Kubi mods and I used .1uf POI instead of wima where applicable.
Selectable curve switch with 6 selections.
edit:
The settings that worked best for me were [Hard to soft]:
Second Vactrol
Big red LED parallel
Small red LED Parallel
100k
1k
Orange Clear LED parallel
Edcor Power Tranx
I used the knobs off an Akai-M8 I hacked for a preamp on a different build...
Pics are a teaser, I will upload some better ones when I get a better cam this week.
« Last Edit: September 28, 2011, 05:01:16 PM by jsefer »
pucho812
Re: D-AOC Porn Inside
« Reply #1 on: September 26, 2011, 02:41:01 AM »
nice are those meters from sifam?
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
jsefer
« Reply #2 on: September 26, 2011, 03:15:49 AM »
Those are the hairball meters... lovely looking if I might say
kepeb
« Reply #3 on: September 26, 2011, 10:28:41 AM »
i recognise the akai knobs :)
good use! looks like an excellent unit
pyinag cosle aentttoin
pucho812
« Reply #4 on: September 26, 2011, 01:24:27 PM »
oh from hairball audio? cool
« Reply #5 on: September 26, 2011, 02:46:24 PM »
nice build jsefer:)
what did you use for your 6 'curve positions' and are they all useable/musical?
cheers
chris
mylesgm
« Reply #6 on: September 26, 2011, 02:56:57 PM »
me too!  I think those old knobs are cool...
Check my work at www.mylesmumford.com
jsefer
« Reply #7 on: September 26, 2011, 03:06:00 PM »
nice build jsefer:)
cheers
chris
Im still experimenting with values, and different leds... the way I built it I used a double row socket connector so that I can swap different LEDs/Resistors for the curve values...
Right now I have in no final order
1k, 100k, red- anti [small led], red[larger] parallel, green led [large], and second vactrol anti-parallel
Musically I really like the red and green leds, they give it  a hard heavy compression setting, not getting good results with vactrol but I asume there might be a false connection somewhere...
My goal is to go from a nice soft compression to a very obvious heavy one...
jsefer
« Reply #8 on: September 26, 2011, 03:19:46 PM »
Yeah, to me this unit looks very, "Militant" has that old soviet look, ha!
jsefer
Re: D-AOC Porn Inside [More Pics Added]
« Reply #9 on: September 27, 2011, 11:42:00 AM »
Added some more pictures  ;D
[silent:arts]
« Reply #10 on: September 28, 2011, 02:25:35 AM »
congrats! nice done!
zayance
« Reply #11 on: September 30, 2011, 11:55:45 AM »
 8), nice one Congrats...
jsefer
« Reply #12 on: October 02, 2011, 05:57:58 AM »
Thanks Man! I really liked your over-all lay-out so I borrowed from it  :P Love this thing, just need to calibrate the channels, in link mode they seem to be well balanced but while in mono theres a huge difference... Also... its acting like a limiter, with a -1 to -2db reduction at 0 compression.. Not that im complaining, its great on the master, as it shaves off just the right amount... but Id like to know whats causing it...
Gotta re-read the 55pages to get some clues..
zayance
« Reply #13 on: October 02, 2011, 06:13:19 AM »
Be my guest, that's why we post the finished stuff, if it can give ideas and inspire....
Indecline
« Reply #14 on: October 02, 2011, 03:22:23 PM »
Man, that's one nice build!! I love the curve 'experiment'  ;D
jsefer
« Reply #15 on: October 06, 2011, 05:04:46 PM »
THanks! I love this thing...
sodderboy
« Reply #16 on: October 07, 2011, 09:33:59 AM »
Looks great!
You should have a bit more space between caps and tubes/sockets.  Give at least a half inch for longevity.
Mike
jsefer
« Reply #17 on: October 09, 2011, 02:59:13 PM »
Looks great!
Mike
I tried to keep things as spacious as i could but, like kubi said, real-estate was scarce. I  did put a case fan at the top of the case. Keeps things very cool.
Blue Jinn
« Reply #18 on: October 18, 2011, 05:01:15 PM »
Nice,
Did you use Shaefer/Front Panel Express for the front panel?
not my thing. I am here just to unbalance the equation --pucho812
 http://www.bluejinn.org
jsefer
« Reply #19 on: October 20, 2011, 02:40:34 PM »
Nice,
I used the front designer to design the panel and had it machined by a local machine shop... he ended up sort of messing up one of the holes on the meter, but it was nothing I couldnt cover it with the meter itself so the job was actually free! I bet you cant tell where its at!
Last post July 27, 2005, 12:22:07 PM
by jensenmann
Last post July 05, 2006, 04:00:23 AM
by Mendelt
Last post December 04, 2009, 09:43:36 AM
by stitch-o
Last post January 13, 2010, 10:27:37 PM
by analag
