I think I am going to pull the trigger on a CNC engraver. I like the looks of this one. http://www.k2cnc.com/shop/proddetail.asp?prod=KT-2514S-09&cat=26
I will get it as a turnkey system with a Bosh Colt router as the spindle to start. I want to engrave and do light milling of aluminum and stainless steel. I don't think the Bosh is up to the task of stainless steel.
I've been looking at fancier spindles but I don't know enough to be sure I'm doing the right thing. I don't have much metal working experience. I think I should get a better feel for it before shelling out for better tooling. I have a few very basic questions that I am embarrassed to ask on CNC Zone.
Is the rotation speed of the cutter for a given material just dependent on the feed rate. In other words if I am working with aluminum can I use any spindle RPM as long as the feed rate matches? Or does a specific aluminum alloy have a an ideal cutter RPM and feed rate.
I'm unclear on the relationship between speed and torque. Is it a fixed relationship or does it vary with motor design?
Do you think a spindle like this http://hptdrivesystems.thomasnet.com/viewitems/z-spindles-2/manual-tool-change? would be good on a desktop system? Better finish, more accurate?
