1176 Hairball/Mnats wrong transistors and diodes?
bram9206
Hello,
I'm building the 1176 rev D Hairball Audio kit with Mnats pcb. I ordered all components via the Mouser card link on the Hairball website, but seems like there are a few things incorrect:
- According to the BOM list I need four 1N4003 rectifiers (CR7, CR8, CR9, CR10) for the power board, but Mouser sent me four 1N4004 rectifiers. Anyone knows the difference? Can I use the 1N4004 instead of the 1N4003?
- Secondary, I need seven 2N3707 transistors (Q5, Q7, Q8, Q9, Q10, Q12, Q13) and Mouser sent me twenty (??) 2N3708 transistors.
Anyone knows the difference? Can I use the 2N3708 instead of the recommened 2N3707?
Thanks in advance!
Bram
You'll be fine with the diodes, the 1n4004 just have a higher voltage rating...not sure about your transistors though. I'm sure one of the 'elders' can advise you better on that one :)
Fine on both counts.
3708 is just a slightly higher gain version of the 3707.
The reason Hairball added 20 to your cart is because you need to match Q12 and Q13.
Welcome to the lab!
