The way your basic info is presented is not understandable. If you have simmed that, you must have some kind of real schemo, mustn't you?warpie said:Are there any disadvantages of inserting a HPF and a LPF as shown below?
Simulation seems to work OK (with about 5.5db/oct.) but I'd like your opinion before I breadboard it.
thanks
w.
abbey road d enfer said:You'd better use C84 to control your HP frequency.
But it would be better to use C82 and C81 for the LP.
Just like you've done with your cap marked HP... But as I said, better use C82. C84 is under the influence of the LC circuit too, which may make it unpredictable. OTOH, with C82, the cut-off frequency is given by F=1/[2pi.(R25+R26).C82]warpie said:I was just thinking of using 1st order filters but I might change it to a higher order (maybe 2nd).
The filters (red caps) in fact will be switchable caps with 6 different Fc.
I'm just trying to insert them to the current circuit but I'm not sure where and how...
How can I use C84 for the HP?abbey road d enfer said:You'd better use C84 to control your HP frequency.
Not much, unless you have very high source impedance like phono cartridge or crystal microphone. The LP frequency is given by F=1/[2pi.(R25.R26/R25+R26).C81]Also, doesn't the input impedance affect the LP?
Yes. If you want to set your LF response there, you need stable capacitors that do not distort under voltage, which pretty much rules out electrolytics.warpie said:abbey road d enfer, newbie question but can I just replace the lytic (C82) with a film cap?
warpie said:Ian, that shouldn't be a problem. For HP I'll probably go as high as 300Hz and for LP maybe down to 3-4K.
Also, is it possible to make 2nd order filters with such configuration?
ruffrecords said:The HP you can make 2nd order fairly easily. You current HP is formed by the HP cap and the 47K input impedance of the stage it feeds. The easiest way to make it 2nd order is to add another HP cap of the same value in series with the first and take the junction of the twocaps to ground via a 47K.
That wouldn't work because C83 is inside the closed-loop.warpie said:Do you believe it is possible to incorporate a second order filter to the current circuit?
I think a 2nd order LP will be possible by switching C81 and C83 simultaneously?
You could switch C97 in the output stage. 100nF there gives you 100Hz turnover frequency.But not sure about the HP...
