G
Guest
Guest
Looking at PRR's simple relay design
I am planning to use 7 relays in the Calrec circuit (I think)
I have a 24V DC power supply coming in just for the relays..
Is it okay just to split the 24v line 7 times before I feed each relay 24V and then use a common ground
The reason I ask is that .. if I do that and press down on one of my SPST pushbuttons will it affect the other relays - or am I thinking too much?
I am replacing the resistor and LED with a 24v lamp (inside the pushbutton - a EAO series 19 locking switch)
one more question...
one of my relays (a 4PCO has an earth pin - do I connect this at all? the other one a 2PCO doesn't have one)
