Just finished my Hairball/Mnats 1176 kit and powered it up. I checked voltages and everything is fine. I calibrated the 1176 without any problem and adjusted the VU meter like it is shown in the movies on mnats.net. Everything seems to work perfect, no noise, compression sounds good, but I have two small issues with the VU meter:
1) When I power up my unit, it takes 10 minutes for the VU meter to get to the zero point. When powering up the meter goes to -05dB and only then within the following 10 minutes it goes very very slowly to the zero point. Once it reached the zero point it stays there for a while, but after a few hours it even goes to +0,5dB. So no big deal here but is this normal?
2) Also, when I change between ratio's (push buttons) my meter goes very quickly to -5dB and then goes back to zero. This is when I go up from 4:1 to for example 8:1. When I go down, from lets say 8:1 to 4:1 the meter goes very quickly from 0 to +3dB and back to zero. Also, when I do the 4-button trick (and here comes the real problem) the meter is at max all the way to the right, even across the +3dB... At this point it's not possible anymore to use the meter for readings. Doesn't seem normal to me either (since my original 1178 doesn't have it). The good thing might be that I don't hear a pop or any click when changing between ratio's.
Anybody any thoughts on this?
For the rest I have only this to say: Mnats and Hairball did an amazing job on this 1176 clone!!!
Bram
