dubwarrior said:
I guess you can use the Transformer wich you prefer..
Something from Edcore, Lundahl or what ever, the guy above has used the original from pultec.
But some recommendations from the designer would be great stil..
Regards
yes, you can use a lot of trasformers made by Edcore, Lundahl , Cinemag, Jensen, Classicapi, OEP, Haufe, Sowter, JLM and others, but regarding out trasformers to put inside the IO board's hole
done for the out trasformer, the trasformers compatible are the following:
BIFILAR TYPES
for 1:1 config.
Jensen JT11-DMCF
CINEMAG CMOB-2H
CINEMAG CMOB-2L
CINEMAG CMOB-2S
I have used the CINEMAG CMOB-2L and I like it very much, good quality at low price , I have not tried the others. It is a clear trasformer with good trasparency, if you want the highest trasparency the CMOB-2H and the Jensen should (should) be to suggest.
Quadfilar output transformers:
for 1:2 or 1:1 configuration
– CLASSICAPI EA2503
– CINEMAG CMOQ-2S
– CINEMAG CMOQ-2L
– CINEMAG CMOQ-2H
– JENSEN TRASFORMERS JT-11SS-DLCF
– JENSEN TRASFORMERS JT-123-ALCF
I have used CLASSICAPI EA2503 and it is very good one as 1:2 config for making sound.
CINEMAG CMOQ-2S is very good also for making sound at 1:2 ratio.
for clear sound with 1:2 ratio JENSEN TRASFORMERS JT-11SS-DLCF is very very good.
The sound is clear but amazing at the same time.
