sr1200
Re: Access-312 Build Thread
« Reply #20 on: November 07, 2011, 06:42:23 PM »
Some pics of my dilemma... iphone pics, best i can do right now
MEI Studio - Long Island, NY: http://www.meirecords.com
toneboner
« Reply #21 on: November 07, 2011, 09:18:50 PM »
@sr1200  --  totally jealous.  even with ur weird 48v voltages ur well on your way. i'm still saving up the scratch for my cinemags...!  what are using the 12v rail for?
@micdaddy  --  the bom i posted was from another thread (cant remember!) and will stuff 4 boards + extras.  Itd be nice to know what someone else thought of the parts -- errors, advice or substitutions...
sr1200
« Reply #22 on: November 07, 2011, 09:42:54 PM »
Got 4 of the 5fish LED VU meters to sit next to each channel.  Im not very optimistic about this one though.  Hopefully the rest of the issues arent anything crazy. I really should have documented the build step by step for this one, would have been easier to track down what i messed up. Lol
3nity
« Reply #23 on: November 07, 2011, 09:49:21 PM »
Ok..(looking at the picture)..the potentiometer...you jumper the wiper (middle pin) with the pin on the bottom WRONG.
you need to jumper the middle (wiper) to the top pin.
Now from the pot.. white wire goes to hole # 1 and black goes to #2.
For jumping JP2...you can use 2 of this below... jumpin 1-2 and 3-4 or just 1 and put on pins 2-3
Thanks.
Life is a path, death the destination.
3nity
« Reply #24 on: November 07, 2011, 09:53:24 PM »
If you dont make a connection at JP2 you wont have sound!
Thanks.
sr1200
« Reply #25 on: November 07, 2011, 11:14:07 PM »
Ok the 48v problem is solved. I rewired the pot as stated and still does nothing. Im using 10k rev log pots(as per bom) and according to the scematic, gain 1 goes to pin 1 and gain 2 goes to 2&3 (the way i had it before) i disconnected the pot and checked on an ohm meter, pot is functioning and values are correct.
Just out of curiosity, i put gain 2 to the wiper and gain1 on one of the outside pins and it works.... Oddddd.
Le Roux
« Reply #26 on: November 08, 2011, 08:26:07 AM »
I am also having troubles with the gain pot.  Nothing until the last 1/4 turn.  Shorting  the gain 1&2 pad, preamp works and sounds great!  Guess I'll try wiring the pot as above post.
3nity
« Reply #27 on: November 08, 2011, 08:38:48 AM »
the shematics says top view...but pins facing the top.
Just to make sure R4 is 100R and R5 is 10K??
If so review the pot pins to the top pin 1 is at the left, wiper: middle and 3rd is the right pin.
wiper and 3rd pin jumpered they go to hole #2 and pin 1 at the left goes to hole #1.
Good luck...
Le Roux
« Reply #28 on: November 08, 2011, 07:48:53 PM »
I also had the pot wiring backwards  :-[
One thing I am noticing though is the pot will not completely shut off audio signal?
Even with pot disconnected, there is still signal going through.
This is on two different boards.
Is this supposed to be like that?
sr1200
« Reply #29 on: November 08, 2011, 11:22:32 PM »
Mine is like that as well, but keep in mind, theres really no reason for it to go to NOTHING, its a mic pre, not a mixer.
manulaudic
« Reply #30 on: November 09, 2011, 05:20:51 AM »
Hi, i'm wondering where did you order your PCB from?
manu
« Reply #31 on: November 09, 2011, 09:48:26 AM »
Some circuits & opamps are not stable at unity gain and not designed to be
see specs where it quotes min & max gain
sr1200
« Reply #32 on: November 10, 2011, 09:43:19 AM »
2 of my channels are working perfectly! :) :) :)
Just waiting on some new (read different) DOAs for my last 2 channels.  Figured id do a pair of 2520's and a pair of ML918's (just to see if I can hear the difference, and IF so, then I have a couple of flavors at my disposal.
3nity
« Reply #33 on: November 10, 2011, 10:12:06 AM »
what was wrong?
Thanks.
sr1200
« Reply #34 on: November 10, 2011, 10:57:40 AM »
Well, besides the 48v problem and the pot problem, there was an odd grounding thing, which i realized that the grounding pin was not attached to the ground pins on the XLR's which got rid of a TON of hum.  Once that was taken care of, i tidied up the case a bit and voila!
Its a pretty aggressive sound, but I like it, its very wide open.  Cant wait to hear what the ML's sound like, supposedly theyre a bit "smoother".
manulaudic
« Reply #35 on: November 10, 2011, 05:37:42 PM »
Have you guys ever compared those to the JLM audio Baby Animal kit?
You can get that Api tone with it too or go some complete different tone (Neve etc...)
Manu
3nity
« Reply #36 on: November 11, 2011, 06:01:55 PM »
Baby Animals are really good but honestly it doestn sound as an API-312 preamp.
Thanks.
manulaudic
« Reply #37 on: November 12, 2011, 05:54:23 AM »
Ok thanks 3nity
frazzman
« Reply #38 on: November 21, 2011, 06:57:26 AM »
Is this the pot at small bear that you're talking about?
http://Http://www.smallbearelec.com/Detail.bok?no=116
Hey.
This build is pretty straightforward build if you follow the BOM.
To answer some questions i will update the BOM.
Thesystem i suggest you take a look at the Meta for some info before starting something that might help you a lot its looking at pics.
But here are some light to your questions:
1- 10K reverse pot 2.50$ at Smallbear good quality.
2- psu adjust voltages: read the meta and do some research.
3- There are too many power transformers so you better look something at RS-Farnell.
4- EA-2622: you need a 150K on RC, 10K at R7-R6 and 220pf at C8.
5- F2UEE are the pushbuttons to go on the access-312...
6- LED, any LED will do the job if it fits you front panel...you solder it to the lugz on the top of the switch.
7- Sockets are there so the op-amps sits on it ..it makes things easier.
8- Gain 1-2 are there so you solder the wires for the pot..you can use molex headers.
9- yes.
3nity
« Reply #39 on: November 24, 2011, 10:10:29 AM »
I cant see what your liks is.
But is a 10K reverse log pot at 2.50$
Last post August 22, 2008, 12:52:22 AM
by Knarleybass
Last post June 29, 2009, 12:50:05 PM
by 3nity
Last post December 19, 2011, 01:05:33 PM
by buildafriend
Last post April 11, 2013, 08:22:09 AM
by amphibic
