For those of you who have any interest in the tools and manufacturing side of things I present the fruit of my diy labor.
Those of you trying to work out from the pictures what the hell I'm making - it's a 3 way solenoid valve controller for a manual solder paste dispenser and vacuum pen device. (a shrink of: http://www.groupdiy.com/index.php?topic=45094.msg568212#msg568212)
(Once completed, Fully Assembled PCB's will be available from the Expat Audio store - the only extras you'll need are the pneumatic parts and a 12VDC power supply)
DSC_0387.JPG by ExpatAudioRochey, on Flickr
These boards were manufacturerd by the excellent seeed studio service, then I created a solder stencil and vacuum placed the resistors, caps and transistors. There's a little few more through hole components to be placed. Nothing too stressful.
The solder paste stencil was created using my CNC machine to drill small 0.9mm holes in the center of each pad. Details in this thread:
http://www.groupdiy.com/index.php?topic=46382.0
The Vacuum Pick and Place pen was created using the circuitry developed in this thread:
http://www.groupdiy.com/index.php?topic=45094.0
1. To start with, a jig was made to hold the pcb's to be stencil'd in place.
Zoom in on the original size image to see how much coverage there is between the stencil hole and the pad itself.
DSC_0384.JPG by ExpatAudioRochey, on Flickr
2. That allows multiple boards (in this case 10) to be stencil'd quickly.
DSC_0385.JPG by ExpatAudioRochey, on Flickr
3. Cut reels of components, and place in component holder, ready to manually vacuum pickplace over to boards!
The skillet was still cold at this point, and unpowered.
The "component holder" is a square of acrylic with 8mm wide, 2mm deep troughs running through it (done on my cnc). I cut the reels of components into 6" strips, tape them down in the grooves, then vacuum pick and place from them.
DSC_0386.JPG by ExpatAudioRochey, on Flickr
4. Manually pick place (no pictures for this... was busy picking and placing!
5.Fire up skillet and reflow (with a little help from a hot air gun from above
.... (again, no pics - was busy trying to get solder to reflow!)
6. Admire handywork and do some quality control.
DSC_0388.JPG by ExpatAudioRochey, on Flickr
All the boards looked great actually. it looks like just the right amount of solder was dispensed!
7. Solder Through Hole Parts (connectors)
TBD - Will Update
8. Basic solder test - apply power and stand back
TBD - Will update
9. Program host controller.
TBD - Code is mostly running on the prototype I built.
TBD - Will Update
TBD - Will update
