G7 Grounding
marktokach
New Braunfels, TX
Ok I have the PSU all wired up except for the ground wire. I have one from the IEC connector, one from Pin 1 on the end of pcb (middle hole out of the 5) one from pin 1 of xlr hooked to pin 1 of pcb. There is a tab that looks like a ground in addition to the 1, 2, 3, pins there. The power switch does not have a ground lug. I know it says it should be star grounded, and in the mic not the power supply but not exactly sure how.
1. Where do I hook the IEC ground to?
2. Should I hook up the extra lug in the XLR to ground?
3. Are there any others that I'm missing that should be hooked up as well, ie. power switch.
This looks pretty much the same as G7. Thanks
This link below is a little confusing. I guess it depends what version of pcb i have which I think is rev. 2 gyraf 2000.
http://www.groupdiy.com/index.php?topic=21769.0
I'm going to hook all grounds to pin 1 xlr 7
